Unexpected ZVol space usage
DavieC
I have some zvols using much more space than expected, and can't figure out why.
We have presented a couple of zvols to our ESX servers. The zvols provisioned at 62TB.
On each of these we have a single 55TB disk presented to a windows guest. These disks are about 75% full.
These virtual disks were vmotion'ed from another SAN platform where space usage was as expected (but it was a traditional block type SAN)
TrueNAS is reporting these zvols are using122TB and 123TB respectively.
There are no snapshots.
Block size was left at default 64KiB
We cant figure out why there is a 100% overhead in space usage.
We have other installations doing the same thing without the large space overhead (there is some overhead, but only small amount)
Running on TrueNAS-SCALE-23.10.1.3
Any pointers on where to look would be much appreciated, we are pulling our hair out here.
dave
DavieC
Humm, I just found this thread, I wonder if this is my problem:
chuck32
Did you provision them as sparse or thick? You mention you're not using snapshots though.
DavieC
Thick provisioned
We did have snapshots configured for replication, but have deleted these while trying to find the source of our problem. We do want to be able to replicate these zvols to another system.
This comment makes me thing it's this refreservation setting, but havent tested.
"When you don't set a zvol to be sparse at creation, a refreservation size is set, meaning it will want the same size as the zvol to be reserved when taking a snapshot (to allow the entire zvol to change without filling the disk)"
Thanks
chuck32
Thick provisioned
Sorry for the late reply, you could use sparse zvols instead or follow the thread you linked (although I have no experience in that, so I can't vouch for anything that comes with it).
You'd need to check the documentation yourself but without specifying anything else
zfs send path/to/your/zvol | zfs receive -v path/to/your/zvol_new will provision the new zvol as sparse ;)
This will create a snapshot and transfer the current state of the zvol to the new zvol.
