Evening -
I just installed FreeNAS SCALE recently - and am impressed. Still getting the hang of things and didn't run into this before - probably because the server I was using didn't have encryption. This install does.
It appears I cannot use a passphrase because the system defaulted to placing the system dataset into the default pool. I'm trying to understand the following:
1) What exactly is the system dataset pool?
2) Was it placed onto the physical drives because I booted off a SD card and it was trying to conserve premature USB/SD Card wear? - I know that's not preferred to use USB/SD Cards, but have it mirrored and am not concerned.
3) Looks like I can go to System Settings -> Advanced -> Configure and point it back to the boot-pool, any advantage in doing that other than it allowing me to use a passphrase instead of a key? Or does keeping it as is help reduce writes to the SD card?
Said differently, it appears the system will automatically decrypt the drives and not prompt for a key or passphrase with this default configuration. If I can prompt to supply a key or enter a key with it like this (instead of a pass phrase) that works also but can't seem to find an option for that.
Thanks
Thanks
