I have the PlexPass plugin installed and it is working. In fact, this is the second time I have had it working. I somehow managed to hose up my system and had to reinstall the plugin to get things back to normal again. Unfortunately, before all this happened, I had spent some time creating a few "Collections" in Plex and also fixing mismatched movie art. Now that I've reinstalled the plugin, I have lost those configurations.
I would like to backup that sort of information. I'm not really sure if you call it "configs" or "meta data" or what.
I already have a dataset mounted into the plugin. That dataset contains all the actual media, so I'm not worried about that.
Based on some other forums I've found, some people suggest doing something similar: create a dataset for configs and mount that into the plugin/jail. My problem is, I have no idea where that data is stored inside the jail. It seems every forum post I find has a different path based on a different version of either plex or Freenas.
Does anyone know for sure, in FreeNas 11.2, what folder or folders I would mount in order to get my configs and/or metadata onto a dataset so that if I have to reinstall the plugin again in the future I can just remount the folder/folders and not lose everything I spent time configuring and fixing?
Thanks so much for any of your help.
