Scharbag
- Feb 1, 2012
My other thread got closed. Please, if you are having this problem, post logs etc.
My original bug report is 28028. It was closed cause it was a duplicate of 27514. 27514's fix seems not to be working fully. As a result, 38923 has been created. 38923 is closed and references 41910 with 41910 referencing a related bug 40600.
All in all, this is a real PITA bug that hopefully will be fixed soon.
My system experienced another unauthorized reboot last night, so it is getting tiresome.
This happened 2 seconds later than my first bug that started the other thread.
So, others that are having this issue, please post with logs. I really hope that 41910 dresses this fault ASAFP. :)
Cheers,
Sep 5 03:03:54 Zhang syslog-ng[1724]: syslog-ng starting up; version='3.7.3' Sep 5 03:03:54 Zhang Fatal double fault Sep 5 03:03:54 Zhang rip 0xffffffff803e5dff rsp 0xfffffe28f6bd1ff0 rbp 0xfffffe28f6bd2050 Sep 5 03:03:54 Zhang rax 0 rdx 0x1 rbx 0xfffff8018aac4b18 Sep 5 03:03:54 Zhang rcx 0x1 rsi 0xfffff8018aac4b18 rdi 0x2304 Sep 5 03:03:54 Zhang r8 0xfffff818195263a0 r9 0 r10 0xfffff814515b6000 Sep 5 03:03:54 Zhang r11 0xffffffff814e670c r12 0xfffff814515b6000 r13 0xfffff818195263f8 Sep 5 03:03:54 Zhang r14 0x2304 r15 0 rflags 0x10246 Sep 5 03:03:54 Zhang cs 0x20 ss 0x28 ds 0x3b es 0x3b fs 0x13 gs 0x1b Sep 5 03:03:54 Zhang fsbase 0x8006e7130 gsbase 0xffffffff821f2800 kgsbase 0 Sep 5 03:03:54 Zhang cpuid = 1; apic id = 01 Sep 5 03:03:54 Zhang panic: double fault Sep 5 03:03:54 Zhang cpuid = 1 Sep 5 03:03:54 Zhang KDB: stack backtrace: Sep 5 03:03:54 Zhang db_trace_self_wrapper() at db_trace_self_wrapper+0x2b/frame 0xfffffe27fc9c9d80 Sep 5 03:03:54 Zhang vpanic() at vpanic+0x186/frame 0xfffffe27fc9c9e00 Sep 5 03:03:54 Zhang panic() at panic+0x43/frame 0xfffffe27fc9c9e60 Sep 5 03:03:54 Zhang dblfault_handler() at dblfault_handler+0x1de/frame 0xfffffe27fc9c9f30 Sep 5 03:03:54 Zhang Xdblfault() at Xdblfault+0xac/frame 0xfffffe27fc9c9f30 Sep 5 03:03:54 Zhang --- trap 0x17, rip = 0xffffffff803e5dff, rsp = 0xfffffe28f6bd1ff0, rbp = 0xfffffe28f6bd2050 --- Sep 5 03:03:54 Zhang dmu_zfetch() at dmu_zfetch+0x2f/frame 0xfffffe28f6bd2050 Sep 5 03:03:54 Zhang dbuf_read() at dbuf_read+0x177/frame 0xfffffe28f6bd20e0 Sep 5 03:03:54 Zhang dnode_hold_impl() at dnode_hold_impl+0x187/frame 0xfffffe28f6bd2160 Sep 5 03:03:54 Zhang dmu_free_long_range() at dmu_free_long_range+0x2a/frame 0xfffffe28f6bd2200 Sep 5 03:03:54 Zhang zfs_rmnode() at zfs_rmnode+0x6a/frame 0xfffffe28f6bd23b0 Sep 5 03:03:54 Zhang zfs_freebsd_reclaim() at zfs_freebsd_reclaim+0x46/frame 0xfffffe28f6bd23e0 Sep 5 03:03:54 Zhang VOP_RECLAIM_APV() at VOP_RECLAIM_APV+0x89/frame 0xfffffe28f6bd2410 Sep 5 03:03:54 Zhang vgonel() at vgonel+0x2a0/frame 0xfffffe28f6bd2490 Sep 5 03:03:54 Zhang vrecycle() at vrecycle+0x4d/frame 0xfffffe28f6bd24c0 Sep 5 03:03:54 Zhang zfs_freebsd_inactive() at zfs_freebsd_inactive+0xd/frame 0xfffffe28f6bd24d0 Sep 5 03:03:54 Zhang VOP_INACTIVE_APV() at VOP_INACTIVE_APV+0x89/frame 0xfffffe28f6bd2500 Sep 5 03:03:54 Zhang vinactive() at vinactive+0xf2/frame 0xfffffe28f6bd2560 Sep 5 03:03:54 Zhang vputx() at vputx+0x2c5/frame 0xfffffe28f6bd25c0 ...
Cheers,
