Hello, my boot drive is giving the following errors when trying to read SMART data and it creates an alert. I believe this started when I applied the most recent update although I'm not certain. I've attempted to downgrade but going from 12.0-u6.1 to u5.1 fails (I can post the log if needed). My data drives are connected to the same Intel controller as below and work fine. Anyone have any ideas on the cause of this? I'd be happy to test downgrading if that's possible. Thanks in advance for any assistance.
***editing to say I'm not exactly sure which of the controllers the drive is connected to, so I tested it in all 6 ports and have the same problem. I suppose it's a drive specific error and probably a problem with the drive hardware?
CPU: i5-3570k
Mobo: Zotac H67ITX-C-E
SATA controllers: JMicron JMB360 and Intel Cougar Point
Drive: ADATA SP550
dmesg | grep SATA
CPU: i5-3570k
Drive: ADATA SP550
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p10 amd64] (local build)
Model Family: Silicon Motion based SSDs
Device Model: ADATA SP550
Serial Number: 2G3820025007
Firmware Version: P0705AB
User Capacity: 240,057,409,536 bytes [240 GB]
Rotation Rate: Solid State Device
TRIM Command: Available, deterministic, zeroed
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed Nov 24 17:57:25 2021 PST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x02) Offline data collection activity
was completed without error.
been run.
data collection: ( 171) seconds.
capabilities: (0x71) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
No Offline surface scan supported.
Self-test supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
Short self-test routine
Extended self-test routine
Conveyance self-test routine
SCT capabilities: (0x0035) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
1 Raw_Read_Error_Rate 0x0000 100 100 000 Old_age Offline - 0
5 Reallocated_Sector_Ct 0x0000 100 100 000 Old_age Offline - 0
9 Power_On_Hours 0x0000 100 100 000 Old_age Offline - 2870
12 Power_Cycle_Count 0x0000 100 100 000 Old_age Offline - 1153
160 Uncorrectable_Error_Cnt 0x0000 100 100 000 Old_age Offline - 0
161 Valid_Spare_Block_Cnt 0x0000 100 100 000 Old_age Offline - 16
163 Initial_Bad_Block_Count 0x0000 100 100 000 Old_age Offline - 361
148 Total_SLC_Erase_Ct 0x0000 100 100 000 Old_age Offline - 136939
149 Max_SLC_Erase_Ct 0x0000 100 100 000 Old_age Offline - 1875
150 Min_SLC_Erase_Ct 0x0000 100 100 000 Old_age Offline - 1730
151 Average_SLC_Erase_Ct 0x0000 100 100 000 Old_age Offline - 1850
164 Total_Erase_Count 0x0000 100 100 000 Old_age Offline - 48886
165 Max_Erase_Count 0x0000 100 100 000 Old_age Offline - 183
166 Min_Erase_Count 0x0000 100 100 000 Old_age Offline - 18
167 Average_Erase_Count 0x0000 100 100 000 Old_age Offline - 38
169 Remaining_Lifetime_Perc 0x0000 100 100 001 Old_age Offline - 97
181 Program_Fail_Cnt_Total 0x0000 100 100 000 Old_age Offline - 0
182 Erase_Fail_Count_Total 0x0000 100 100 000 Old_age Offline - 0
192 Power-Off_Retract_Count 0x0000 100 100 000 Old_age Offline - 40
194 Temperature_Celsius 0x0000 100 100 070 Old_age Offline - 27 (35 35 35 35 0)
199 UDMA_CRC_Error_Count 0x0000 100 100 000 Old_age Offline - 0
232 Available_Reservd_Space 0x0000 100 100 000 Old_age Offline - 100
241 Host_Writes_32MiB 0x0000 100 100 000 Old_age Offline - 161699
242 Host_Reads_32MiB 0x0000 100 100 000 Old_age Offline - 125139
245 TLC_Writes_32MiB 0x0000 100 100 000 Old_age Offline - 288732
246 SLC_Writes_32MiB 0x0000 100 100 000 Old_age Offline - 273878
247 Raid_Recoverty_Ct 0x0000 100 100 000 Old_age Offline - 0
Read SMART Error Log failed: Input/output error
Read SMART Self-test Log failed: Input/output error
Read SMART Selective Self-test Log failed: Input/output error
dmesg | grep SATA
ahci0: <JMicron JMB360 AHCI SATA controller> port 0xd040-0xd047,0xd030-0xd033,0xd020-0xd027,0xd010-0xd013,0xd000-0xd00f mem 0xf7d10000-0xf7d101ff irq 17 at device 0.0 on pci3
atapci0: <Intel Cougar Point SATA600 controller> port 0xf110-0xf117,0xf100-0xf103,0xf0f0-0xf0f7,0xf0e0-0xf0e3,0xf0d0-0xf0df,0xf0c0-0xf0cf irq 19 at device 31.2 on pci0
atapci1: <Intel Cougar Point SATA300 controller> port 0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf090-0xf097,0xf080-0xf083,0xf070-0xf07f,0xf060-0xf06f irq 19 at device 31.5 on pci0
ada0: <ADATA SP550 P0705AB> ACS-2 ATA SATA 3.x device
ada0: 600.000MB/s transfers (SATA 3.x, UDMA5, PIO 1024bytes)
ada1: <WDC WD120EMFZ-11A6JA0 81.00A81> ACS-2 ATA SATA 3.x device
ada1: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
ada2: <WDC WD120EDAZ-11F3RA0 81.00A81> ACS-2 ATA SATA 3.x device
ada2: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
ada3: <WDC WD120EMFZ-11A6JA0 81.00A81> ACS-2 ATA SATA 3.x device
ada3: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes)
