First off, I am a newbie with limited Linux knowledge.
I am trying to setup FreeNAS on an old laptop that I had. I have installed FreeNAS-8.0.4-RELEASE-p2-x86 (11367) on a USB drive and have the laptop set to autoboot to the USB drive. That worked great!
I have also been able to set up a new volume for a USB drive that I attached to the laptop. Works great!
The problem I am having is that I would like to import the NTFS hard drive from the laptop as a volume. However, each time I attempt to do so from the WebUI I get the following error: "An error occurred while labeling the disk."
If I attempt to mount the drive from the shell using the mount, mount_ntfs or mount_ntfs-kern command then I get the error "No such file or directory".
I am not really sure where to go from here. Any and all help would be GREATLY APPRECIATED!!
Thanks in Advance!
Thanks in Advance!
