Unable to modify custom SMART task
dfnas
The issue I'm having is that when I create a custom S.M.A.R.T. task that, for example, runs on Mondays, Wednesdays, and Fridays at 2AM, then afterwards, I edit it to run on Tuesdays, Thursdays, and Saturdays at 2AM, the system won't allow me to modify it, saying there's already a SMART task that runs at 2AM. I have to delete the old task before I can create a new one, instead of just modifying the old one.
What I had found in older versions (and haven't tested since as I just adjusted my process to work around it) is that changes made to SMART tasks don't really work. You need to create new tasks rather than modify existing ones.
That drives me to the behavior of never modifying my SMART schedules once set.
