Unable to join into AD
wasim
Hi..
I need assistance for joining Freenas into Windowser server 2012 AD.
Thanks,
Walter
You'll have to be a lot more informative than that. We have no idea what your setup is and what problems you're facing.
wasim
Hi.. i followed each and every step in that document..but unable to AD users are login into the NAS Server
wasim
I able to add windows server 2012 AD but AD usera are unable to login.. Please check the attached image for your reference and please help me out of this..
jgreco
Resident Grinch
Fiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiine
jgreco
Resident Grinch
Moved to offtopic because this doesn't really seem FreeNAS related, except possibly incidentally.
You have provided no useful information and just showed us a screencap of the CLI. Which you shouldn't even be using.
If you want help, you'll have to carefully explain what you have done. Do not expect people to hold your hand through the process, that's what the manual is for.
wasim
I Have added Windows server 2012 AD to freenas but it not showing the AD users and not allowing the AD users to login.
jgreco
Resident Grinch
And the FreeNAS system and the users all have appropriate privileges?
anodos
Sambassador
Post following enclosed in [ code ] tags:
  • Hardware specs of server
  • contents of /etc/local/smb4.conf
  • output of 'wbinfo -u'
  • output of 'wbinfo -g'
  • output of 'getent group'
  • relevant log entries from /var/log/messages, /var/log/samba4/log.wb-<domain>
wasim
Hard ware specs of Windows Sevrer 2012 AD :
Server Version: Windows Server 2012 R2
RAM : 4 GB
domain; in.spinsci.com
HDD : 80 GB
Attached are teh outputs of the required.The logs are very large in number so that unable to ake screen shot if any other way is available let me know so that i can provide you logs.
Thanks,
walter
anodos
Sambassador
RAM : 4 GB
HDD : 80 GB
Thanks,
walter
I was referring to the hardware specs of your freenas server. You can enable ssh and copy the information out of a proper ssh session or use scp / sftp to download the relevant files.
anodos
Sambassador
You have configured your FreeNAS server as an AD domain controller. This means you now have two distinct AD domains configured on your network, which is not a desirable configuration. I believe you're trying to join it as an AD member server (not a domain controller), correct?
gpsguy
Active Member
We need the hardware specs of your FreeNAS server.
What version of FreeNAS, including the embedded date are you running.
Sent from my phone
