jbranlizrd
 - Jun 14, 2021
Can't install plugins. On the "Choose pool for plugins and jail storage", I select "Storage" as my dataset pool. It then gives me this error.
CallError
[EFAULT] Failed to activate Storage : cannot open 'Storage': dataset does not exist
			CallError
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/zfs.py", line 20, in run
    cp.check_returncode()
  File "/usr/local/lib/python3.9/subprocess.py", line 460, in check_returncode
    raise CalledProcessError(self.returncode, self.args, self.stdout,
subprocess.CalledProcessError: Command '['zfs', 'get', '-H', '-o', 'name,property,value', '-t', 'filesystem', 'all', 'Storage', 'boot-pool']' returned non-zero exit status 1.
  File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/jail_freebsd.py", line 1467, in activate
    iocage.activate(pool['name'])
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/iocage.py", line 379, in activate
    pool.deactivate_pool()
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/pools.py", line 51, in deactivate_pool
    Dataset(self.name, cache=self.cache).set_property(
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/dataset.py", line 38, in __init__
    self._properties = deepcopy(cache.datasets.get(self.resource_name))
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/cache.py", line 72, in datasets
    ioc_pool = self.iocage_activated_pool_internal(lock=False)
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/cache.py", line 42, in iocage_activated_pool_internal
    all_properties([p for p in pools], types=['filesystem'])
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/zfs.py", line 72, in all_properties
    data = run([
  File "/usr/local/lib/python3.9/site-packages/iocage_lib/zfs.py", line 22, in run
    raise ZFSException(cp.returncode, cp.stderr)
iocage_lib.zfs.ZFSException: cannot open 'Storage': dataset does not exist
  File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 137, in call_method
    result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self,
  File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1209, in _call
  File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1113, in run_in_executor
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
  File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 977, in nf
    return f(*args, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/jail_freebsd.py", line 1469, in activate
    raise CallError(f'Failed to activate {pool["name"]}: {e}')
middlewared.service_exception.CallError: [EFAULT] Failed to activate Storage : cannot open 'Storage': dataset does not exist
