Unable to import volume in fresh FN 11.1 install
thenerb
I just installed a fresh install of FN 11.1 U6.3 on my server. The server was previously running 8.3.1 and was long overdue for an upgrade. Rather than go through the upgrade process, since my config was very basic and I've only been using as a local home file server, I elected to start with a fresh install and try importing the volume. I am getting the below error (see attached TXT file), but am unsure what this means and what actions I should take to remedy. The hard drives were all listed as "healthy" before I shut down the 8.3.1 server.
The setup is RAIDZ1 with 5 x 2TB HDD's. Hardware is a Gigabyte MB with AMD Athlon 64bit processor and 8GB of RAM. Boot drive is a 120GB Crucial SSD.
Thank you.
Import Volume
Request Method: POSTRequest URL: http://192.168.86.120/storage/auto-import/Software Version: FreeNAS-11.1-U6.3 (35cbff5a1)Exception Type: CallTimeoutException Value: Call timeout
Exception Location: /usr/local/lib/python3.6/site-packages/middlewared/client/client.py in call, line 429Server time: Fri, 4 Jan 2019 18:17:20 -0800
  • freenasimporterror.txt
thenerb
Disregard. Oddly the volume is now imported and I see it and am able to access the files. Problem resolved! :)
