Unable to enable LDAP Authentication on 9.3
Mindwarper
The system is running FreeNAS-9.3-STABLE-201504100216. Fresh install, nothing fancy. I've configured the hostname and domain. I enter the applicable data into the GUI for the LDAP configuration, and attempt to save. The GUI pops up with a 'The service failed to restart'. I'm sure I'm missing something simple...
I don't see anything that is a specific error during the event, the /var/log/debug.log output during that timeframe:
Apr 13 13:48:42 freenas manage.py: [middleware.notifier:224] Calling: start(ldap)
Apr 13 13:48:42 freenas manage.py: [middleware.notifier:190] Executing: /etc/directoryservice/LDAP/ctl start
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:938] FreeNAS_LDAP.__init__: enter
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:512] FreeNAS_LDAP_Base.__init__: enter
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:487] FreeNAS_LDAP_Base.__set_defaults: enter
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:499] FreeNAS_LDAP_Base.__set_defaults: leave
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:125] FreeNAS_LDAP_Directory.__init__: enter
Apr 13 13:48:44 freenas ldaptool: [common.frenascache:305] FreeNAS_LDAP_QueryCache.__init__: enter
Apr 13 13:48:44 freenas ldaptool: [common.frenascache:97] FreeNAS_BaseCache._init__: enter
Apr 13 13:48:44 freenas ldaptool: [common.frenascache:112] FreeNAS_BaseCache._init__: cachedir = /var/tmp/.cache/.query
Apr 13 13:48:44 freenas ldaptool: [common.frenascache:114] FreeNAS_BaseCache._init__: cachefile = /var/tmp/.cache/.query/.cache.db
Apr 13 13:48:44 freenas ldaptool: [common.frenascache:115] FreeNAS_BaseCache._init__: leave
Apr 13 13:48:44 freenas ldaptool: [common.frenascache:313] FreeNAS_LDAP_QueryCache.__init__: leave
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:169] FreeNAS_LDAP_Directory.__init__: host = dc04.olympus.mysite.com, port = 389, binddn = cn=_ldap,OU=Service Accounts,OU=Users,OU=IT,DC=olympus,DC=mysite,DC=com, basedn = dc=olympus,dc=mysite,dc=com, ssl = off
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:170] FreeNAS_LDAP_Directory.__init__: leave
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:250] FreeNAS_LDAP_Directory.open: enter
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:257] FreeNAS_LDAP_Directory.open: uri = ldap://dc04.olympus.mysite.com:389
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:260] FreeNAS_LDAP_Directory.open: initialized
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:297] FreeNAS_LDAP_Directory.open: trying to bind
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:215] FreeNAS_LDAP_Directory.open: (authenticated bind) trying to bind to dc04.olympus.mysite.com:389
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:299] FreeNAS_LDAP_Directory.open: binded
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:311] FreeNAS_LDAP_Directory.open: connection open
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:313] FreeNAS_LDAP_Directory.open: leave
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:696] FreeNAS_LDAP_Base.get_user_by_DN: enter
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:697] FreeNAS_LDAP_Base.get_user_by_DN: DN = cn=_ldap,OU=Service Accounts,OU=Users,OU=IT,DC=olympus,DC=mysite,DC=com
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:331] FreeNAS_LDAP_Directory._search: enter
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:333] FreeNAS_LDAP_Directory._search: basedn = 'cn=_ldap,OU=Service Accounts,OU=Users,OU=IT,DC=olympus,DC=mysite,DC=com', filter = '(objectclass=*)'
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:406] FreeNAS_LDAP_Directory._search: pagesize = 0
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:435] FreeNAS_LDAP_Directory._search: 1 results
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:436] FreeNAS_LDAP_Directory._search: leave
Apr 13 13:48:44 freenas ldaptool: [common.freenasldap:725] FreeNAS_LDAP_Base.get_user_by_DN: leave
Apr 13 13:48:44 freenas manage.py: [middleware.notifier:204] Executed: /etc/directoryservice/LDAP/ctl start; returned 1
Apr 13 13:48:44 freenas manage.py: [middleware.notifier:190] Executing: /usr/sbin/service ix-ldap status
Apr 13 13:48:46 freenas manage.py: [middleware.notifier:204] Executed: /usr/sbin/service ix-ldap status; returned 1
Thanks in advance!
-MW
D
dlavigne
Guest
I think you are hitting this (from the UPGRADING file):
3. Authenticating via LDAP now requires that the connection to the LDAP server be SSL/TLS. This prevents account passwords from being sent in clear-text but may be an unexpected change in behavior for users upgrading from older releases of FreeNAS.
Does importing the cert for the LDAP server using System -> Certificates, then selecting that cert in the Certificates drop-down menu in the Advanced Mode of Directory -> LDAP fix it?
Mindwarper
Good catch, I did test that a bit ago, but I had forgotten about it. It appears to have the same issue. Debug output:
Apr 13 15:47:19 freenas3 manage.py: [middleware.notifier:190] Executing: /usr/sbin/service ix-ldap status
Apr 13 15:47:21 freenas3 manage.py: [middleware.notifier:204] Executed: /usr/sbin/service ix-ldap status; returned 1
Apr 13 15:47:21 freenas3 manage.py: [middleware.notifier:224] Calling: start(ldap)
Apr 13 15:47:21 freenas3 manage.py: [middleware.notifier:190] Executing: /etc/directoryservice/LDAP/ctl start
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:938] FreeNAS_LDAP.__init__: enter
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:512] FreeNAS_LDAP_Base.__init__: enter
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:487] FreeNAS_LDAP_Base.__set_defaults: enter
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:499] FreeNAS_LDAP_Base.__set_defaults: leave
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:125] FreeNAS_LDAP_Directory.__init__: enter
Apr 13 15:47:23 freenas3 ldaptool: [common.frenascache:305] FreeNAS_LDAP_QueryCache.__init__: enter
Apr 13 15:47:23 freenas3 ldaptool: [common.frenascache:97] FreeNAS_BaseCache._init__: enter
Apr 13 15:47:23 freenas3 ldaptool: [common.frenascache:112] FreeNAS_BaseCache._init__: cachedir = /var/tmp/.cache/.query
Apr 13 15:47:23 freenas3 ldaptool: [common.frenascache:114] FreeNAS_BaseCache._init__: cachefile = /var/tmp/.cache/.query/.cache.db
Apr 13 15:47:23 freenas3 ldaptool: [common.frenascache:115] FreeNAS_BaseCache._init__: leave
Apr 13 15:47:23 freenas3 ldaptool: [common.frenascache:313] FreeNAS_LDAP_QueryCache.__init__: leave
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:169] FreeNAS_LDAP_Directory.__init__: host = dc03.olympus.mysite.com, port = 636, binddn = cn=_ldap,OU=Service Accounts,OU=Users,OU=IT,DC=olympus,DC=mysite,DC=com, basedn = dc=olympus,dc=mysite,dc=com, ssl = on
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:170] FreeNAS_LDAP_Directory.__init__: leave
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:593] FreeNAS_LDAP_Base.__init__: leave
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:942] FreeNAS_LDAP.__init__: leave
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:250] FreeNAS_LDAP_Directory.open: enter
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:257] FreeNAS_LDAP_Directory.open: uri = ldaps://dc03.olympus.mysite.com:636
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:260] FreeNAS_LDAP_Directory.open: initialized
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:297] FreeNAS_LDAP_Directory.open: trying to bind
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:215] FreeNAS_LDAP_Directory.open: (authenticated bind) trying to bind to dc03.olympus.mysite.com:636
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:299] FreeNAS_LDAP_Directory.open: binded
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:311] FreeNAS_LDAP_Directory.open: connection open
Apr 13 15:47:23 freenas3 ldaptool: [common.freenasldap:313] FreeNAS_LDAP_Directory.open: leave
Apr 13 15:47:23 freenas3 alert.py: [middleware.notifier:208] Popen()ing: /sbin/zpool status -x freenas-boot
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.freenasldap:938] FreeNAS_LDAP.__init__: enter
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.freenasldap:512] FreeNAS_LDAP_Base.__init__: enter
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.freenasldap:487] FreeNAS_LDAP_Base.__set_defaults: enter
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.freenasldap:499] FreeNAS_LDAP_Base.__set_defaults: leave
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.freenasldap:125] FreeNAS_LDAP_Directory.__init__: enter
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.frenascache:305] FreeNAS_LDAP_QueryCache.__init__: enter
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.frenascache:97] FreeNAS_BaseCache._init__: enter
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.frenascache:112] FreeNAS_BaseCache._init__: cachedir = /var/tmp/.cache/.query
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.frenascache:114] FreeNAS_BaseCache._init__: cachefile = /var/tmp/.cache/.query/.cache.db
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.frenascache:115] FreeNAS_BaseCache._init__: leave
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.frenascache:313] FreeNAS_LDAP_QueryCache.__init__: leave
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.freenasldap:169] FreeNAS_LDAP_Directory.__init__: host = dc03.olympus.mysite.com, port = 636, binddn = cn=_ldap,OU=Service Accounts,OU=Users,OU=IT,DC=olympus,DC=mysite,DC=com, basedn = dc=olympus,dc=mysite,dc=com, ssl = on
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.freenasldap:170] FreeNAS_LDAP_Directory.__init__: leave
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.freenasldap:593] FreeNAS_LDAP_Base.__init__: leave
Apr 13 15:47:30 freenas3 generate_sssd_conf.py: [common.freenasldap:942] FreeNAS_LDAP.__init__: leave
Apr 13 15:47:42 freenas3 manage.py: [middleware.notifier:204] Executed: /etc/directoryservice/LDAP/ctl start; returned 1
Apr 13 15:47:42 freenas3 manage.py: [middleware.notifier:190] Executing: /usr/sbin/service ix-ldap status
Apr 13 15:47:45 freenas3 manage.py: [middleware.notifier:204] Executed: /usr/sbin/service ix-ldap status; returned 1
D
dlavigne
Guest
Just to confirm, the LDAP server is running ldaps on port 636?
Mindwarper
Yesum. Logs on both sides show the bind success and the lookup of the bind user account (when using a Kerberos realm)
D
dlavigne
Guest
Please create a bug report at bugs.freenas.org and post the issue number here.
