Unable to Create Volume
Good afternoon All,
Problem Description:
When I try to create a volume, either manually or through the wizard, the Create Volume window closes without any sort of message (error or success) and no volumes are visible in "View Volumes".
Example:
Click Volume Manager
1. Revert to Manual Setup
2. Name the volume
3. Select disks - there are 4 disks visible, ada0,1,2,3
4. Select all disks and select RAID-Z2 (for example)
5. Click Add volume
6. Progress bar briefly appears, then disappears and you're on Storage --> Volumes, with no Volume.
I've scanned for existing forums and not been able to find a solution.
Debug file is attached.
Hardware is:
1. HP ML150 G6
2. Intel Xeon E5502 @ 1.87GHz (single processor)
3. 8GB Kingston
4. 4x 1TB Western Digital - AHCI enabled in BIOS. Each drive connected directly to motherboard with 1 SATA cable each. I had deleted, quick formatted and then deleted each drive's volume in Win8 x64 prior to installation into the ML150 chassis.
5. No add-on cards.
6. On-board LAN.
7. FreeNAS 9.3-STABLE-201505130355 is installed onto an 8GB USB stick which is connected via the on-board USB port. It was installed via a bootable DVD created by downloading the ISO from the site.
Device requirements: I want to create an iSCSI target for use by a VMWare ESXi 6 host. This is not for a live environment - only for the creation of VM's for testing purposes.
[root@freenas ~]# gpart show
=> 34 15187901 da0 GPT (7.2G)
34 1024 1 bios-boot (512k)
1058 6 - free - (3.0k)
1064 15185920 2 freebsd-zfs (7.2G)
15186984 951 - free - (475k)
=> 63 1953253313 raid/r0 MBR (931G)
63 1953253313 - free - (931G)
=> 63 1953253313 raid/r128 MBR (931G)
=> 63 1953253313 raid/r1 MBR (931G)
Other info:
I used the same iso to create a FreeNAS Virtual Machine (ESXi 5.1) and succesfully created an iSCSI target without issue - so I added a 20GB hard drive, created a volume and configured the iSCSI components.
I hope I managed to get all the required info here, so I look forward to any advice that you may have, thank you.
  • debug-freenas-20150612044057.tgz
Quick update: I am now running DBAN on each of the 4 1TB WD drives. They were originally in a production environment configured in a RAID1 set on an Adaptec RAID card. Just wondering if this may be the cause. Will find out next week.
That could well be the cause, though I'd still expect an error message. FreeNAS really doesn't like to overwrite used disks if it can tell there's something on them.
DrKK
FreeNAS Generalissimo
I suspect the problem is an old partition table. Very often, the ZFS formatting will fail if an old partition table is on there. You can wipe it out by doing a short first sectors overwrite with dd, or whatever other method you have at your disposal for wiping the drive.
Looking much better now.
Left the server running DBAN over the weekend and after a reboot and into FreeNAS, the problem now was that FreeNAS was not detecting the 4 1TB WD's drives.
So, I rebooted again with the FreeNAS DVD in the drive bay and used it to do a fresh install on the USB drive attached to the mainboard. After the fresh installation and a reboot, logged into FreeNAS console and there were the 4 drives. Onto Volume Manager and after the first attempt, I have a volume. Problem solved.
Thank you to all who took the time to read and to Danb35 and DrKK for responding!
