UI Buttons Unresponsive
gannon
Not sure exactly where to put this or even exactly what to call it.
Ever since I updated to 11.1-u4, using the old UI, some buttons edits/new etc. become unresponsive. I can still move around in the UI tabs and areas but can't do much configuration without buttons bringing up windows. I can solve the bug by logging out and logging back in. I usually get 1 crack at a create/edit and then the bug returns and I have to relog again.
It happens on both Chrome and IE.
Using the new UI seems to improve the amount of time between unresponsiveness but it still returns.
Functionally I see no problems as everything configured seems to work fine.
Any ideas?
gannon
Dell r510
Single E5640
16Gb
3 volumes
10 drives
Haven't changed anything since the issue started.
D
dlavigne
Guest
Anything in /var/log/messages when it happens? Are you behind a proxy or firewall or having any network issues?
