Hi there,
OK - so, I was gone for the weekend, and when I came back tonight, had this nasty surprise in my daily freenas e-mail :
Checking status of zfs pools:
pool: Raidz2
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: http://www.sun.com/msg/ZFS-8000-9P
scrub: scrub completed after 8h0m with 0 errors on Wed Feb 22 03:20:22 2012
NAME STATE READ WRITE CKSUM
Raidz2 ONLINE 0 0 0
raidz2 ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
ada1p2 ONLINE 0 0 0
ada3p2 ONLINE 0 0 0
ada4p2 ONLINE 0 0 0
ada5p2 ONLINE 0 0 0
ada6p2 ONLINE 3 813K 0
spares
ada7p2 AVAIL
errors: No known data errors
Had the same thing the day before, with the same drive being affected (ada6p2), with very slightly different numbers. Everything still works. So, I'm guessing faulty drive. That's fine...but, the security output goes like this :
freenas.local kernel log messages:
+++ /tmp/security.dmGAPA7C 2012-03-18 03:01:10.000000000 -0600
+xptioctl: pass driver is not in the kernel
+xptioctl: put "device pass" in your kernel config file
...on and on and on, for several lines. Is this also related to the (assumed) faulty drive?
So - assuming it's a faulty drive, is there somewhere that relates specifically how to replace a drive? Also, is there a quick way to find out which of my 7 drives ada6p2 is?
Thanks! =)
pool: Raidz2
state: ONLINE
Raidz2 ONLINE 0 0 0
raidz2 ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
ada1p2 ONLINE 0 0 0
ada3p2 ONLINE 0 0 0
ada4p2 ONLINE 0 0 0
ada5p2 ONLINE 0 0 0
spares
ada7p2 AVAIL
Thanks! =)
