firesyde424
Member
- Mar 5, 2019
We are in the process of working through a new FreeNAS server build for use as a misc, high IO, network storage SAN. We weren't able to find a lot of information on this kind of build so I thought I'd post it here.
Most of this storage will be use via NFS for non-production and dev ESXI container workloads as well as PostgreSQL database storage. The remainder is slated as a place to store our daily backup deltas before they are moved off to mechanical storage.
- Dell PowerEdge R7525, 2RU server
- 2 x AMD Epyc 7542 CPUs - 64 cores total @ 2.9Ghz (Yes, I realize this is massive overkill for a normal FreeNAS, but past experience with disk failures while under high IO load has taught us to go over the top on CPU)
- 6 x 64GB DDR4 RDIMM - 384GB Total
- 4x Micron 32GB DDR4 NVDIMM-N Modules
- Used in two mirrors as SLOG devices
- 24 x Micron 9300 Pro 15.36TB U.2 NVME
- 2 x Intel XXV710 Dual Port 10/25Gbe Adapters
- 2 x 240GB M.2 drives on a BOSS PCI Express card in RAID1
- Used as a boot drive
