Hello Folks,
I am trying to setup FreeNAS 9.2.1.4 on a PC as iSCSI block storage, for MPIO access to my home study lab running two Hyper-V 2012R2 Nodes in a cluster (CSV). I have successfully set up two volumes (a small Quorum disk and one storage disk) thru one of the NIC. It all works great.
Now, I have added another NIC on separate subnet and added that IP address to existing portal so as to present the same two volumes. But on trying to discover / connect to this second portal IP address, thru Microsoft iSCSI initiator, I always get connection failure. I have reachability, tested via pings from the Hyper-V nodes.
Trying to create a new portal, then require a new target / extent, while I want to serve the same disks via to separate portals / NICs for resiliency and load balancing via MPIO.
Please advise and much appreciate.
