Hi Folks,
I have a question about how I can add a second bridge interface and do explicit mapping,
So it stays persistent post-reboot.
In my case, I have two 10Gbe in LAG and two VLAN interfaces i.e subinterface)
VLAN X and VLAN Y interfaces.
- VM (Tap interface connected) VLAN X
- single jail instance connected to VLAN Y.
FreeNAS adds both VLAN X and Y and jail and VM to the same bridge and it creates an issue.
I have to manually remove the VLAN interface, tap the interface, and create a second bridge manually.
(in essence, I fix that by removing interface vlan50 and tap from the first bridge
and creating the second bridge).
bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
ether 02:d7:4a:fb:ce:00
nd6 options=1<PERFORMNUD>
groups: bridge
member: vlan10 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 2000000
--> if boot jail it will land here ( and it correct)
(Manually created. By default all TAP / Jail and vlanX land in bridge0
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
ether 02:d7:4a:fb:ce:01
groups: bridge
member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 8 priority 128 path cost 2000000
member: vlan50 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 2000000
