I did a replication to an extra disk as a backup, but I only did 1 dataset, I can't seem to replicate other datasets to it, so I assume it's a pool to pool thing or something... so I went to start over.
I tried to delete the dataset but it wouldn't do anything, so I removed the whole volume. I can't re-add the disk or wipe it due to the known issue... so I found the thread here and went to run the commands, but the last dd is not working.
One of my 2 new disks that I moved everything to is flapping off/on and causing non-stop reslivering only to go offline and come back a few minutes later. I'm nervous to power down right now without a good backup, so I'm trying to get a snapshot and replication going to this other disk before I reboot, but having problems re-adding it.
What can I do to get past this so I can make this disk a fresh volume to replicate to?
Thanks
[root@nas ~]# dd if=/dev/zero of=/dev/da3 bs=1m count=1
1+0 records in
1+0 records out
1048576 bytes transferred in 0.007951 secs (131874373 bytes/sec)
[root@nas ~]# dd if=/dev/zero of=/dev/da3 bs=1m oseek=`diskinfo da3 | awk '{print int($3 / (1024/1024)) - 4;}'`
dd: /dev/da3: Input/output error
1+0 records in
0+0 records out
0 bytes transferred in 0.000476 secs (0 bytes/sec)
[root@nas ~]# dmesg | grep da3
GEOM: da3: the primary GPT table is corrupt or invalid.
GEOM: da3: using the secondary instead -- recovery strongly advised.
isci: 1628416236:600315 ISCI isci: bus=21 target=1 lun=0 cdb[0]=da3979f0 terminated
GEOM_MIRROR: Cannot open consumer da3p1 (error=1).
GEOM_MIRROR: Cannot open consumer da3p1 (error=1). One of my 2 new disks that I moved everything to is flapping off/on and causing non-stop reslivering only to go offline and come back a few minutes later. I'm nervous to power down right now without a good backup, so I'm trying to get a snapshot and replication going to this other disk before I reboot, but having problems re-adding it.
Thanks
