Help getting UFS pool back in freenas 11
coneill
So I recently upgraded from 9.3 to 11 and my old pool with a single UFS drive isn't loading. I saw UFS is pretty much gone now in freenas 11. Ok no problem, Its just a single backup disk anyway. However I've spent the last 5 hours trying to import the single disk back as a single drive ZFS but I keep getting these errors every time I try to create a new pool with it.
Nov 22 13:45:43 freenas GEOM_ELI: Device mirror/swap1.eli destroyed.
Nov 22 13:45:43 freenas GEOM_MIRROR: Device swap1: provider destroyed.
Nov 22 13:45:43 freenas GEOM_MIRROR: Device swap1 destroyed.
Nov 22 13:45:44 freenas notifier: 32+0 records in
Nov 22 13:45:44 freenas notifier: 32+0 records out
Nov 22 13:45:44 freenas notifier: 33554432 bytes transferred in 0.362878 secs (92467551 bytes/sec)
Nov 22 13:45:44 freenas GEOM: ada1: corrupt or invalid GPT detected.
Nov 22 13:45:44 freenas GEOM: ada1: GPT rejected -- may not be recoverable.
Nov 22 13:45:44 freenas notifier: dd: /dev/ada1: short write on character device
Nov 22 13:45:44 freenas notifier: dd: /dev/ada1: end of device
Nov 22 13:45:44 freenas notifier: 33+0 records in
Nov 22 13:45:44 freenas notifier: 32+1 records out
Nov 22 13:45:44 freenas notifier: 33644544 bytes transferred in 0.517276 secs (65041827 bytes/sec)
Nov 22 13:45:46 freenas uwsgi: [middleware.exceptions:36] [MiddlewareError: Unable to create the pool: cannot open '/dev/gptid/d1fdd612-ee86-11e8-86f5-bc5ff4457497': No such file or directory, ]
Nov 22 13:45:58 freenas GEOM_MIRROR: Device mirror/swap1 launched (2/2).
Nov 22 13:45:58 freenas GEOM_ELI: Device mirror/swap1.eli created.
Nov 22 13:45:58 freenas GEOM_ELI: Encryption: AES-XTS 128
Nov 22 13:45:58 freenas GEOM_ELI:	 Crypto: software
Ive tried getting rid of the first and last sectors
dd of=/dev/zero if=/dev/ada1 count=100
dd of=/dev/zero if=/dev/ada1 count=100 seek=39007029067
because I read of the drive hanging onto the GPT partitions but that doesn't seem to work. I've tried doing
gpart destroy -F /dev/ada1
but then I get an error that the device is busy. I've also tried
swapoff -a
and then all of the above but that also doesn't let me create a new pool with this disk.
Chris Moore
UFS is not supported in modern versions of FreeNAS. It has not been supported for several years. I don't know what you are trying to accomplish with all those commands. Are you trying to destroy your data?
If you want to wipe the disk and create a ZFS pool on it, you do that from the GUI.
coneill
understood that UFS is no longer supported. I used this UFS disk in Freenas9 to do local backups so I wanted to turn it into a ZFS pool in FreeNAS 11 to keep doing local backups to it. When I wasn't able to create the pool at first in the GUI I saw some posts on here with something about old drives from another FreeNAS install keeping information on some sectors of the disk so I figured I'd just wipe the disk so it was clean and then like you said use the GUI to create a new pool and then just rsync all my data back to it. But every step of the way the using GUI generates an error. Last night I let the Wipe -> Full with Zeros command run from the GUI on the disk and still this morning I can't create a pool with it. I keep getting the same error messages every time that I posted above no matter what I try to do to make the disk look "clean" to FreeNAS
If there is any additional information I can provide Id be happy to.
