puppabriggy
- Sep 25, 2022
I picked an off the wall project. I'm running a DIY NAS setup based on 12vdc power. I initially started experiencing IO errors (see post below). After swapping out everything, case, cables, MD, power supplies I realized the IO errors could be power related and were triggered during high CPU usage. Once I figured out hardware transcoding (plex) the problem more or less resolved.
Right now the system works without issue when on batter( this is a solar setup), but once the batteries run low I switch to an AC - DC 12 supply that is suppose to be rated at 600W. When I use the AC-DC supply the I/O errors come back. Now it is possible amazon is lying about the power supply rating (note the power supply is behind a regulator). I'm just looking or ideas I may have missed
12 AC-DC
250W Power Supply
Regulator
I/O Errors
12 AC-DC
250W Power Supply
Regulator
I/O Errors
CAM Status: Uncorrectable parity error/CRC Error MB or Case?
I have been ttrying out a NAS case (link below), and have been getting a few parity errors. I pulled the drives connected them directly (no back plane) errors seem to stop. So I requested a new case hoping the errors would go away, initially so far so good, then after a day reocccuring errors...www.truenas.com
