devnullius
- Dec 9, 2015
I just enabled Port Aggregation. My router has 2 dedicated LACP ports which I connected to my 2x NIC of the FreeNAS server.
Now I'm testing the network transfer speed and improvement is not that much... I now touch about 900Mbps. It should be more.
The pool I transfer to should support 8x 300MB/s/disk (about 3Gbps/disk). The network connection should be at least 2Gbps. The file(s) I'm transferring are big backup files from Windows Backup. I used link aggregation on my server too. While not the dedicated 2x LACP ports, windows happily reports a 2Gbps connection speed.
See my signature for the specs:
My htop is >100. Reporting --> CPU gives a value of about 70 (60 to 80 in the graphs). Wired RAM is 38GB. HDD usages is low.
What would you guys first impression be here?
Post-edit: reading this one, looks interesting: https://forums.freenas.org/index.php?threads/build-and-performance-tuning-advice-needed.54833/
