Ok, so my setup is like this:
I have 4 dell r710 servers with four 1Gb ports each. One server is running Truenas, the other 3 are running Proxmox. In order to isolate the traffic between each of the four servers from my household network I created a bridge (bridge192) on each server and added the last 3 physical ports as members. Each of the last three physical ports on each of the four servers connect directly to one of the remaining three servers so that each server has a direct 1Gb connection to all of the others.
The proxmox servers can all communicate (ping) each other with this configuration but not the Truenas server, likewise the Truenas server cannot ping any of the other servers over the bridged connection. This leads me to believe I have a configuration problem with my Truenas bridge. I set it up using the GUI interface.
My bridge IP addresses for the servers are (addresses are not assigned to bridge members):
Proxmox1: 192.113.1.1/24
Proxmox2: 192.113.1.2/24
Proxmox3: 192.113.1.3/24
Truenas : 192.113.1.10/24
Version: TrueNAS-12.0-U4.1
Output of ifconfig:
If anyone can shed some light on why Truenas doesnt want to talk I would appreciate it. I suspect I am overlooking a BSD specific config option, or that maybe BSD doesnt like the direct peer-to-peer connection with the other servers, but im not sure and dont know how to check it.
Output of ifconfig:
root@truenas[~]# ifconfig
bce0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=c01bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,VLAN_HWTSO,LINKSTATE>
        ether 84:2b:2b:76:97:5a
        inet 10.113.2.10 netmask 0xffffff00 broadcast 10.113.2.255
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
bce1: flags=8902<BROADCAST,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 84:2b:2b:76:97:5c
        nd6 options=1<PERFORMNUD>
bce2: flags=8902<BROADCAST,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 84:2b:2b:76:97:5e
bce3: flags=8902<BROADCAST,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 84:2b:2b:76:97:60
        options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
        groups: lo
pflog0: flags=0<> metric 0 mtu 33160
        groups: pflog
bridge192: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        ether 02:bf:01:42:0b:c0
        inet 192.113.1.10 netmask 0xffffff00 broadcast 192.113.1.255
        maxage 20 holdcnt 6 proto stp-rstp maxaddr 2000 timeout 1200
        member: bce1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 2 priority 128 path cost 55
        member: bce3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 4 priority 128 path cost 55
        member: bce2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 3 priority 128 path cost 55
        groups: bridge
        nd6 options=9<PERFORMNUD,IFDISABLED>If anyone can shed some light on why Truenas doesnt want to talk I would appreciate it. I suspect I am overlooking a BSD specific config option, or that maybe BSD doesnt like the direct peer-to-peer connection with the other servers, but im not sure and dont know how to check it.
