roysen
- Dec 11, 2021
My TrueNas box has two network cards. One Intel X520 with dual-port that is combined into lagg0. It also has an integrated em0 card that I use as a bridge for my VM.
When running iperf3 it seems to use my lagg0 network for incoming connections but when I run it the other way it seems like it uses my bridge or em0. Bridging seems to make so many problems on FreeNas. Does anyone have a solution to how to set this up without losing connections between my host and its VM and at the same time being able to use the full speed of my 10Gb network card?
Iperf3 is started like this on my TrueNas: iperf3 -s -B 192.168.68.5
From my workstation:
Iperf3 in Reverse mode from my workstation:
ipconfig output:
iperf3 -c 192.168.68.5 Connecting to host 192.168.68.5, port 5201 [ 4] local 192.168.68.100 port 36358 connected to 192.168.68.5 port 5201 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 1.02 GBytes 8.79 Gbits/sec [ 4] 1.00-2.00 sec 1.10 GBytes 9.43 Gbits/sec [ 4] 2.00-3.00 sec 1.10 GBytes 9.44 Gbits/sec [ 4] 3.00-4.00 sec 1.10 GBytes 9.45 Gbits/sec [ 4] 4.00-5.00 sec 1.10 GBytes 9.44 Gbits/sec [ 4] 5.00-6.00 sec 1.10 GBytes 9.44 Gbits/sec [ 4] 6.00-7.00 sec 1.10 GBytes 9.46 Gbits/sec [ 4] 7.00-8.00 sec 1.10 GBytes 9.45 Gbits/sec [ 4] 8.00-9.00 sec 1.10 GBytes 9.44 Gbits/sec [ 4] 9.00-10.00 sec 1.10 GBytes 9.45 Gbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth [ 4] 0.00-10.00 sec 10.9 GBytes 9.38 Gbits/sec sender [ 4] 0.00-10.00 sec 10.9 GBytes 9.38 Gbits/sec receiver
iperf3 -c 192.168.68.5 -R Connecting to host 192.168.68.5, port 5201 Reverse mode, remote host 192.168.68.5 is sending [ 4] local 192.168.68.100 port 37214 connected to 192.168.68.5 port 5201 [ ID] Interval Transfer Bandwidth [ 4] 0.00-1.00 sec 107 MBytes 899 Mbits/sec [ 4] 1.00-2.00 sec 112 MBytes 941 Mbits/sec [ 4] 2.00-3.00 sec 112 MBytes 942 Mbits/sec [ 4] 3.00-4.00 sec 112 MBytes 942 Mbits/sec [ 4] 4.00-5.00 sec 112 MBytes 940 Mbits/sec [ 4] 5.00-6.00 sec 112 MBytes 942 Mbits/sec [ 4] 6.00-7.00 sec 112 MBytes 942 Mbits/sec [ 4] 7.00-8.00 sec 112 MBytes 942 Mbits/sec [ 4] 8.00-9.00 sec 112 MBytes 942 Mbits/sec [ 4] 9.00-10.00 sec 112 MBytes 942 Mbits/sec - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bandwidth Retr [ 4] 0.00-10.00 sec 1.09 GBytes 938 Mbits/sec 0 sender [ 4] 0.00-10.00 sec 1.09 GBytes 938 Mbits/sec receiver
ipconfig output:
ix0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
description: member of lagg0
options=e53fbb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,WOL_UCAST,WOL_MCAST,WOL_MAGIC,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether 00:1b:21:a3:94:48
media: Ethernet autoselect (10Gbase-Twinax <full-duplex,rxpause,txpause>)
status: active
ix1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
hwaddr 00:1b:21:a3:94:49
status: active
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=812098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWFILTER>
ether bc:ee:7b:df:f7:a8
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x4
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
description: Bridge for VMs
ether 02:7a:ae:08:2c:00
inet 192.168.68.6 netmask 0xffffff00 broadcast 192.168.68.255
maxage 20 holdcnt 6 proto stp-rstp maxaddr 2000 timeout 1200
member: vnet0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 2000000
member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 3 priority 128 path cost 55
groups: bridge
vnet0: flags=8942<BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=80000<LINKSTATE>
ether fe:a0:98:ff:ff:ff
hwaddr 58:9c:fc:10:ff:b6
groups: tap
status: active
nd6 options=1<PERFORMNUD>
Opened by PID 1505
lagg0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
description: lagg0
inet 192.168.68.5 netmask 0xffffff00 broadcast 192.168.68.255
laggproto lacp lagghash l2,l3,l4
laggport: ix0 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
laggport: ix1 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
groups: lagg
status: active
