Logger: homeassistant.components.hue.config_flow
Source: components/hue/config_flow.py:77
Integration: Philips Hue (
documentation,
issues)
First occurred: 02:47:03 (3 occurrences)
Last logged: 02:53:29
Error while attempting to retrieve discovery information, is there a bridge alive on IP 192.168.32.44 ?Traceback (most recent call last):
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 980, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore[return-value] # noqa
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1085, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 1069, in create_connection
sock = await self._connect_sock(
File "/usr/local/lib/python3.11/asyncio/base_events.py", line 973, in _connect_sock
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 628, in sock_connect
return await fut
File "/usr/local/lib/python3.11/asyncio/selector_events.py", line 668, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
ConnectionRefusedError: [Errno 111] Connect call failed ('192.168.32.44', 80)
The above exception was the direct cause of the following exception:
File "/usr/src/homeassistant/homeassistant/components/hue/config_flow.py", line 77, in _get_bridge
bridge = await discover_bridge(
File "/usr/local/lib/python3.11/site-packages/aiohue/discovery.py", line 36, in discover_bridge
bridge_id = await is_hue_bridge(host, websession)
File "/usr/local/lib/python3.11/site-packages/aiohue/discovery.py", line 82, in is_hue_bridge
async with websession.get(url, timeout=30) as res:
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 1141, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 536, in _request
conn = await self._connector.connect(
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 540, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 901, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 1209, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 1178, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
File "/usr/local/lib/python3.11/site-packages/aiohttp/connector.py", line 988, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host 192.168.32.44:80 ssl:default [Connect call failed ('192.168.32.44', 80)]
