Truenas Scale Shell Time not matching System time
urfrndsandy
Hello Community,
I am trying a Test Environment for Truenas scale and will move this to production if everything works.
Currently on a fresh installation of Truenas Scale after setting the NTP servers and also updating time zone, the GUI shows correct time.
However when i check in shell I get a time offset of around 5 hours, what could be the reason, I am unable to Join Active directory.
Shell output
root@truenas[~]# date
Tue May 30 23:47:06 IST 2023
GUI From System Settings ----> General
Configuration
Test Environment on VM player with 16 GB Ram and i5 2400 CPU
What timezone is your AD running in?
flashdrive
I do have the reverse issue - UEFI time is correct, and "date" in TN shell will show the offset
