TrueNAS Scale Shell Not Readable
TYFLOOZY
Hello, for some reason I cannot see the details of my shell and has been going on for quite a while. Can anyone point me in the right direction for how to fix this?
That's bizarre, kinda like a VGA card stuck in the wrong mode. Tell us more about your system...
TYFLOOZY
Current Hardware: IX Systems Mini+, Currently on Cobia (TrueNAS-SCALE-23.10.0.1). This has been going on for months, just haven't tackled this project yet.
What's the output of zpool status?
TYFLOOZY
That's a great question, I'm not sure where to look for that, I'm a beginner (sorry for the hassle).
Is that something I search in the shell for or just look at my main pool in datasets?
Yes, just run that in the shell.
TYFLOOZY
So If I copy the info and paste into Notepad or something text based, I'm able to view the data, see below (hopefully there isn't anything confidential in the info below):
root@truenas[~]# zpool status               pool: Main Pool
 state: ONLINE
  scan: scrub repaired 0B in 10:56:49 with 0 errors on Sun Jan 21 11:56:52 2024
        NAME                                      STATE     READ WRITE CKSUM
        Main Pool                                 ONLINE       0     0     0
          mirror-0                                ONLINE       0     0     0
            b97fbabe-50e3-4d8d-ae1c-191ec678510d  ONLINE       0     0     0
            c99de1ea-0b88-4322-8288-69eaef796e86  ONLINE       0     0     0
errors: No known data errors
  pool: boot-pool
 state: ONLINE
  scan: scrub repaired 0B in 00:00:19 with 0 errors on Tue Feb  6 03:45:20 2024
        boot-pool    ONLINE       0     0     0
          nvme0n1p3  ONLINE       0     0     0
Hmm, no obvious corruption in the boot pool. Did you at any point touch the underlying terminal settings?
TYFLOOZY
Sorry for the late response, I have not messed with the terminal, I don't know much terminal stuff. If I do then I'm just following other people's commands to achieve a task.
TYFLOOZY
Thank you all for your help, I got it figured out. I was using LibreWolf as my browser, same error shows in Mullvad. Something to do with the hardening with the browser. The Shell works in Brave and I'm assuming less hardened browsers.
I appreciate it!
