TrueNAS Scale Repeated Kernel Panics
Chewie198
I have a TrueNAS server that I've been maintaining for roughly a decade, going back to the FreeNAS 9 days. The first several years were on dedicated hardware and then eventually I migrated it to a Proxmox VM with dedicated SAS and networking passthrough on a Supermicro EYPC server. Last month I updated from TrueNAS Core 12.0-u8 to TrueNAS-SCALE-22.02.0.1 in order to take advantage of some of the improved synergies running Linux guests under KVM. The migration process itself completed successfully, and I only had to make a few manual changes afterwards to get my shares back online and networking configured correctly.
Functionally, I can access the data shares just fine, scrubs complete with no errors, and most of the dashboard functions normally, but certain operations like replications after the intial one are hanging indefinitely in waiting status or failing with errors. I'm also unable to update the read-only attribute on a mirrored pool with no errors. It just hangs on the spinning circle. The dashboard also reports that 4 out of the 6 CPU cores are at 100% perpetually, although the Proxmox metrics indicate that CPU usage for the VM is at less than 1%. I'm seeing repeated recoverable kernel panics being logged to the console, with no indication of why. One of my 4-drive RaidZ-2 arrays lost two drives roughly a month ago, and so I have a single alert in the console related to those two drives being taken offline (and physically removed from the server), but no other alerts are present. What might be causing these errors and how can I prevent them? I'm about to migrate the entire RaidZ-2 array to SSDs due to the failed drives and wanted to get some insight into this issue before I do so.
If it makes any difference to the troubleshooting process, I have a single Intel Optane NVMe drive attached to the pool as a log device as well. I have no errors ocurring in other VMs on the same server or the hypervisor itself, and no hardware errors logged in the BMC. This was also not occurring under TrueNAS Core 12.0-u8. Shutdown and startup of the VM takes over 15 fifteen minutes sometimes now during the Import or detach Pools phase, but eventually completes successfully.
Apr 20 17:19:20 freenas kernel: task:txg_sync        state:D stack:    0 pid: 3742 ppid:     2 flags:0x00004000
Apr 20 17:19:20 freenas kernel: Call Trace:
Apr 20 17:19:20 freenas kernel:  __schedule+0x282/0x870
Apr 20 17:19:20 freenas kernel:  schedule+0x46/0xb0
Apr 20 17:19:20 freenas kernel:  vcmn_err.cold+0x7e/0x80 [spl]
Apr 20 17:19:20 freenas kernel:  ? spl_kmem_cache_alloc+0x97/0x7c0 [spl]
Apr 20 17:19:20 freenas kernel:  ? zfs_btree_remove_idx+0xb4/0x9d0 [zfs]
Apr 20 17:19:20 freenas kernel:  ? zfs_btree_insert_into_leaf+0x233/0x2a0 [zfs]
Apr 20 17:19:20 freenas kernel:  zfs_panic_recover+0x6d/0x90 [zfs]
Apr 20 17:19:20 freenas kernel:  range_tree_add_impl+0x305/0xe40 [zfs]
Apr 20 17:19:20 freenas kernel:  ? lock_timer_base+0x61/0x80
Apr 20 17:19:20 freenas kernel:  ? _cond_resched+0x16/0x40
Apr 20 17:19:20 freenas kernel:  ? mutex_lock+0xe/0x30
Apr 20 17:19:20 freenas kernel:  ? txg_list_add+0x7a/0x90 [zfs]
Apr 20 17:19:20 freenas kernel:  metaslab_free_concrete+0x11d/0x250 [zfs]
Apr 20 17:19:20 freenas kernel:  metaslab_free_impl+0xa9/0xe0 [zfs]
Apr 20 17:19:20 freenas kernel:  metaslab_free+0x168/0x190 [zfs]
Apr 20 17:19:20 freenas kernel:  zio_free_sync+0xda/0xf0 [zfs]
Apr 20 17:19:20 freenas kernel:  dsl_scan_free_block_cb+0x65/0x1a0 [zfs]
Apr 20 17:19:20 freenas kernel:  bpobj_iterate_blkptrs+0xfe/0x360 [zfs]
Apr 20 17:19:20 freenas kernel:  ? dsl_scan_free_block_cb+0x1a0/0x1a0 [zfs]
Apr 20 17:19:20 freenas kernel:  bpobj_iterate_impl+0x29a/0x550 [zfs]
Apr 20 17:19:20 freenas kernel:  dsl_scan_sync+0x552/0x1350 [zfs]
Apr 20 17:19:20 freenas kernel:  ? kfree+0xba/0x480
Apr 20 17:19:20 freenas kernel:  ? bplist_iterate+0x115/0x130 [zfs]
Apr 20 17:19:20 freenas kernel:  spa_sync+0x5b3/0xfa0 [zfs]
Apr 20 17:19:20 freenas kernel:  ? spa_txg_history_init_io+0x101/0x110 [zfs]
Apr 20 17:19:20 freenas kernel:  txg_sync_thread+0x2e0/0x4a0 [zfs]
Apr 20 17:19:20 freenas kernel:  ? txg_fini+0x250/0x250 [zfs]
Apr 20 17:19:20 freenas kernel:  thread_generic_wrapper+0x6f/0x80 [spl]
Apr 20 17:19:20 freenas kernel:  ? __thread_exit+0x20/0x20 [spl]
Apr 20 17:19:20 freenas kernel:  kthread+0x11b/0x140
Apr 20 17:19:20 freenas kernel:  ? __kthread_bind_mask+0x60/0x60
Apr 20 17:19:20 freenas kernel:  ret_from_fork+0x22/0x30
Apr 20 17:21:20 freenas kernel: task:txg_sync        state:D stack:    0 pid: 3742 ppid:     2 flags:0x00004000
Apr 20 17:21:20 freenas kernel: Call Trace:
Apr 20 17:21:20 freenas kernel:  __schedule+0x282/0x870
Apr 20 17:21:20 freenas kernel:  schedule+0x46/0xb0
Apr 20 17:21:20 freenas kernel:  vcmn_err.cold+0x7e/0x80 [spl]
Apr 20 17:21:20 freenas kernel:  ? spl_kmem_cache_alloc+0x97/0x7c0 [spl]
Apr 20 17:21:20 freenas kernel:  ? zfs_btree_remove_idx+0xb4/0x9d0 [zfs]
Apr 20 17:21:20 freenas kernel:  ? zfs_btree_insert_into_leaf+0x233/0x2a0 [zfs]
Apr 20 17:21:20 freenas kernel:  zfs_panic_recover+0x6d/0x90 [zfs]
Apr 20 17:21:20 freenas kernel:  range_tree_add_impl+0x305/0xe40 [zfs]
Apr 20 17:21:20 freenas kernel:  ? lock_timer_base+0x61/0x80
Apr 20 17:21:20 freenas kernel:  ? _cond_resched+0x16/0x40
Apr 20 17:21:20 freenas kernel:  ? mutex_lock+0xe/0x30
Apr 20 17:21:20 freenas kernel:  ? txg_list_add+0x7a/0x90 [zfs]
Apr 20 17:21:20 freenas kernel:  metaslab_free_concrete+0x11d/0x250 [zfs]
Apr 20 17:21:20 freenas kernel:  metaslab_free_impl+0xa9/0xe0 [zfs]
Apr 20 17:21:20 freenas kernel:  metaslab_free+0x168/0x190 [zfs]
Apr 20 17:21:20 freenas kernel:  zio_free_sync+0xda/0xf0 [zfs]
Apr 20 17:21:20 freenas kernel:  dsl_scan_free_block_cb+0x65/0x1a0 [zfs]
Apr 20 17:21:20 freenas kernel:  bpobj_iterate_blkptrs+0xfe/0x360 [zfs]
Apr 20 17:21:20 freenas kernel:  ? dsl_scan_free_block_cb+0x1a0/0x1a0 [zfs]
Apr 20 17:21:20 freenas kernel:  bpobj_iterate_impl+0x29a/0x550 [zfs]
Apr 20 17:21:20 freenas kernel:  dsl_scan_sync+0x552/0x1350 [zfs]
Apr 20 17:21:20 freenas kernel:  ? kfree+0xba/0x480
Apr 20 17:21:20 freenas kernel:  ? bplist_iterate+0x115/0x130 [zfs]
Apr 20 17:21:20 freenas kernel:  spa_sync+0x5b3/0xfa0 [zfs]
Apr 20 17:21:20 freenas kernel:  ? spa_txg_history_init_io+0x101/0x110 [zfs]
Apr 20 17:21:20 freenas kernel:  txg_sync_thread+0x2e0/0x4a0 [zfs]
Apr 20 17:21:20 freenas kernel:  ? txg_fini+0x250/0x250 [zfs]
Apr 20 17:21:20 freenas kernel:  thread_generic_wrapper+0x6f/0x80 [spl]
Apr 20 17:21:20 freenas kernel:  ? __thread_exit+0x20/0x20 [spl]
Apr 20 17:21:20 freenas kernel:  kthread+0x11b/0x140
Apr 20 17:21:20 freenas kernel:  ? __kthread_bind_mask+0x60/0x60
Apr 20 17:21:20 freenas kernel:  ret_from_fork+0x22/0x30
Chewie198
Quick update - I was hoping to test out the point update but that got pushed back to next week so I went ahead and migrated to pool to SSDs. I was able to narrow this down to the failing replication task. I restored my Data pool back to fully Online status, no alerts present, and the VM performed as expected. As soon as I kicked off the replication task, I began seeing the kernel errors in the console and it would appear to begin hanging some of the background worker threads. At that point, I would see a replication failure alert after several hours due to an inability to delete old snapshots. And the hung background threads would show on the dash as all cores at 100% CPU, even though most areas of the dash were navigable and performant. However, certain pool actions on the replication target would hang until a reboot, like export, attribute modification, deletion, etc. Then on shutdown all of the hung threads required a full 10 minutes or so to respond to a SIGTERM, whereas bootup and pool import happens in just a few minutes now.
The interesting thing is that this problem doesn't manifest itself until after the initial replication. I can destroy the pool and start from scratch and everything copies over fine, so this definitely looks like a bug in the replication code. However, since I just migrated from CORE and I just edited the replication type to perform a Full Filesystem Replication rather than a normal recursive one, I haven't been able to isolate the root cause yet. Running a full replication on this system takes roughly twelve hours to complete so once the current replication is done running I'll do some experimenting to see if I can break it again and update the thread. If anyone else is seeing any similar issues with failing replications I hope this helps. And I'll try out the point release on Wednesday in case that has any bearing on the issue.
