Truenas Scale - random restarts
hrayrwannis
dear Forum,
I've been having some random restarts on my truenas scale system recently. The server is home server for media, running plex, security cams and backups.
Some server details:
- TrueNAS-SCALE-22.12.3.3
- Cpu: 13th Gen Intel(R) Core(TM) i7-13700K
- motherboard: CUK ASRock H670M-ITX/ax Mini ITX Motherboard for 12th Gen Intel LGA 1700 CPUs at 125W PL1 with PCIe 5.0 x16 Graphics
- RAM: Corsair Vengeance LPX 64GB (2x 32GB) DDR4 3200(PC4-25600) C161.35V Desktop Memory -Black
- 1 pool if RAIDz1: 3X Seagate Exos X18 18TB Enterprise HDD - CMR 3.5 Inch Hyperscale SATA 6Gb/s, 7200 RPM, 512e and 4Kn FastFormat, Low Latency with Enhanced Caching (ST18000NM000J)
- SSD boot drive: KINGSTON SA400S37120G
I've seen some other random restart posts though nothing similar (i think).
the output from sudo journalctl | grep shutdow (as suggested in another post) puts out the below- though not sure what to make of it?
admin@truenas[~]$ sudo journalctl | grep shutdown
Nov 06 15:37:17 truenas systemd[1]: Starting ix-shutdown.service - Exec TrueNAS shutdown tasks...
Nov 06 15:37:17 truenas systemd[1]: Finished ix-shutdown.service - Exec TrueNAS shutdown tasks.
Nov 06 15:37:48 truenas systemd[1]: Reached target virt-guest-shutdown.target - Libvirt guests shutdown.
Nov 06 15:38:50 truenas dockerd[7762]: time="2023-11-06T15:38:50.269563841+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:38:52 truenas dockerd[7762]: time="2023-11-06T15:38:52.668538448+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:38:53 truenas dockerd[7762]: time="2023-11-06T15:38:53.426279349+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:38:55 truenas dockerd[7762]: time="2023-11-06T15:38:55.866497759+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:38:57 truenas dockerd[7762]: time="2023-11-06T15:38:57.675739095+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:38:58 truenas dockerd[7762]: time="2023-11-06T15:38:58.040707733+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:02 truenas dockerd[7762]: time="2023-11-06T15:39:02.514074849+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:03 truenas dockerd[7762]: time="2023-11-06T15:39:03.495791121+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:04 truenas dockerd[7762]: time="2023-11-06T15:39:04.281718861+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:05 truenas dockerd[7762]: time="2023-11-06T15:39:05.418371383+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:09 truenas dockerd[7762]: time="2023-11-06T15:39:09.412939088+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:09 truenas dockerd[7762]: time="2023-11-06T15:39:09.638988416+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:09 truenas dockerd[7762]: time="2023-11-06T15:39:09.894333935+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:10 truenas dockerd[7762]: time="2023-11-06T15:39:10.512864766+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:10 truenas dockerd[7762]: time="2023-11-06T15:39:10.806928552+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:10 truenas dockerd[7762]: time="2023-11-06T15:39:10.916438986+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:11 truenas dockerd[7762]: time="2023-11-06T15:39:11.104364241+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:12 truenas dockerd[7762]: time="2023-11-06T15:39:12.809380609+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:13 truenas dockerd[7762]: time="2023-11-06T15:39:13.264368076+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:13 truenas dockerd[7762]: time="2023-11-06T15:39:13.486929885+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:13 truenas dockerd[7762]: time="2023-11-06T15:39:13.801884132+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:14 truenas dockerd[7762]: time="2023-11-06T15:39:14.443780302+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:14 truenas dockerd[7762]: time="2023-11-06T15:39:14.640154438+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:14 truenas dockerd[7762]: time="2023-11-06T15:39:14.949278707+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:15 truenas dockerd[7762]: time="2023-11-06T15:39:15.938361807+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:16 truenas dockerd[7762]: time="2023-11-06T15:39:16.178494534+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:16 truenas dockerd[7762]: time="2023-11-06T15:39:16.766698675+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:17 truenas dockerd[7762]: time="2023-11-06T15:39:17.729655916+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:18 truenas dockerd[7762]: time="2023-11-06T15:39:18.546200602+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:19 truenas dockerd[7762]: time="2023-11-06T15:39:19.120429328+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:20 truenas dockerd[7762]: time="2023-11-06T15:39:20.420498520+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:20 truenas dockerd[7762]: time="2023-11-06T15:39:20.571493823+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:21 truenas dockerd[7762]: time="2023-11-06T15:39:21.650580781+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:22 truenas dockerd[7762]: time="2023-11-06T15:39:22.075676979+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:22 truenas dockerd[7762]: time="2023-11-06T15:39:22.246205368+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:23 truenas dockerd[7762]: time="2023-11-06T15:39:23.081504387+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:24 truenas dockerd[7762]: time="2023-11-06T15:39:24.480887647+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:26 truenas dockerd[7762]: time="2023-11-06T15:39:26.194442122+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:26 truenas dockerd[7762]: time="2023-11-06T15:39:26.421661230+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:26 truenas dockerd[7762]: time="2023-11-06T15:39:26.586854563+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:26 truenas dockerd[7762]: time="2023-11-06T15:39:26.699494365+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:27 truenas dockerd[7762]: time="2023-11-06T15:39:27.510889656+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:28 truenas dockerd[7762]: time="2023-11-06T15:39:28.364252616+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:29 truenas dockerd[7762]: time="2023-11-06T15:39:29.033791819+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:29 truenas dockerd[7762]: time="2023-11-06T15:39:29.724073607+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:30 truenas dockerd[7762]: time="2023-11-06T15:39:30.158971528+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:30 truenas dockerd[7762]: time="2023-11-06T15:39:30.846636508+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:31 truenas dockerd[7762]: time="2023-11-06T15:39:31.114919816+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:31 truenas dockerd[7762]: time="2023-11-06T15:39:31.464272407+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:31 truenas dockerd[7762]: time="2023-11-06T15:39:31.762487097+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:31 truenas dockerd[7762]: time="2023-11-06T15:39:31.888612093+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:32 truenas dockerd[7762]: time="2023-11-06T15:39:32.337202662+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:33 truenas dockerd[7762]: time="2023-11-06T15:39:33.458249744+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:34 truenas dockerd[7762]: time="2023-11-06T15:39:34.054737224+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:34 truenas dockerd[7762]: time="2023-11-06T15:39:34.548786373+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:35 truenas dockerd[7762]: time="2023-11-06T15:39:35.342518749+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:35 truenas dockerd[7762]: time="2023-11-06T15:39:35.818036532+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:36 truenas dockerd[7762]: time="2023-11-06T15:39:36.044396201+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:36 truenas dockerd[7762]: time="2023-11-06T15:39:36.945653744+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:39 truenas dockerd[7762]: time="2023-11-06T15:39:39.011038368+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:39 truenas dockerd[7762]: time="2023-11-06T15:39:39.241458897+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:39 truenas dockerd[7762]: time="2023-11-06T15:39:39.803705442+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:41 truenas dockerd[7762]: time="2023-11-06T15:39:41.811306784+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:42 truenas dockerd[7762]: time="2023-11-06T15:39:42.831319305+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:43 truenas dockerd[7762]: time="2023-11-06T15:39:43.862575085+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:45 truenas dockerd[7762]: time="2023-11-06T15:39:45.039939414+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:45 truenas dockerd[7762]: time="2023-11-06T15:39:45.795952018+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:46 truenas dockerd[7762]: time="2023-11-06T15:39:46.065929182+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:46 truenas dockerd[7762]: time="2023-11-06T15:39:46.994440005+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:47 truenas dockerd[7762]: time="2023-11-06T15:39:47.965835384+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:48 truenas dockerd[7762]: time="2023-11-06T15:39:48.328798252+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:49 truenas dockerd[7762]: time="2023-11-06T15:39:49.220809912+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:49 truenas dockerd[7762]: time="2023-11-06T15:39:49.481154087+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:50 truenas dockerd[7762]: time="2023-11-06T15:39:50.218268861+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:51 truenas dockerd[7762]: time="2023-11-06T15:39:51.193974421+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:51 truenas dockerd[7762]: time="2023-11-06T15:39:51.840036245+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:52 truenas dockerd[7762]: time="2023-11-06T15:39:52.292191227+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:53 truenas dockerd[7762]: time="2023-11-06T15:39:53.135339132+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:53 truenas dockerd[7762]: time="2023-11-06T15:39:53.846771425+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:54 truenas dockerd[7762]: time="2023-11-06T15:39:54.115385835+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:55 truenas dockerd[7762]: time="2023-11-06T15:39:55.917588597+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:56 truenas dockerd[7762]: time="2023-11-06T15:39:56.383990015+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:56 truenas dockerd[7762]: time="2023-11-06T15:39:56.830573079+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:58 truenas dockerd[7762]: time="2023-11-06T15:39:58.012656399+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:39:59 truenas dockerd[7762]: time="2023-11-06T15:39:59.264327995+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:40:00 truenas dockerd[7762]: time="2023-11-06T15:40:00.056762626+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:40:00 truenas dockerd[7762]: time="2023-11-06T15:40:00.332671290+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:40:01 truenas dockerd[7762]: time="2023-11-06T15:40:01.016969963+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:40:02 truenas dockerd[7762]: time="2023-11-06T15:40:02.249012350+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:40:02 truenas dockerd[7762]: time="2023-11-06T15:40:02.729524120+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:40:57 truenas dockerd[7762]: time="2023-11-06T15:40:57.826148401+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:41:09 truenas dockerd[7762]: time="2023-11-06T15:41:09.861091178+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:41:14 truenas dockerd[7762]: time="2023-11-06T15:41:14.287827539+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:41:21 truenas dockerd[7762]: time="2023-11-06T15:41:21.308989387+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:41:21 truenas dockerd[7762]: time="2023-11-06T15:41:21.901467222+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:42:03 truenas dockerd[7762]: time="2023-11-06T15:42:03.467988439+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:42:03 truenas dockerd[7762]: time="2023-11-06T15:42:03.900395669+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:42:07 truenas dockerd[7762]: time="2023-11-06T15:42:07.742862066+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:42:07 truenas dockerd[7762]: time="2023-11-06T15:42:07.838417683+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:44:25 truenas dockerd[7762]: time="2023-11-06T15:44:25.172877574+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
Nov 06 15:44:49 truenas dockerd[7762]: time="2023-11-06T15:44:49.268468106+03:00" level=info msg="loading plugin \"io.containerd.internal.v1.shutdown\"..." runtime=io.containerd.runc.v2 type=io.containerd.internal.v1
From monitoring the reporting on truenas scale you can see the dropout at 15:34 and comes back 14 15:40:
similarly the outputs from multireport.ch on disk health is attached.
Where can i look perhaps for more evidence what can be the culpirt?
thanks in advance.
  • Multi-Report v2.4.3 dtd2023-06-16 (.txt
sfatula
I suspect the problem occured before 15:37:17 since that's where shutdown started, but the question is why did it start, so any relevant log entries should be posted before that time.
hrayrwannis
thanks a lot for your response. Any idea how i can get the logs before?
