Truenas SCALE iscsi multipath configuration
uberiain
Hello, I have a little lab with 3 XenServer 8.2 ( or xcp-ng 8.2) connected to a TrueNAS-12.0-U5.1 using iSCSI multipath with the parameters defined on multipath.conf as recomended on Multipath config for TrueNAS.
Connecting the 3 XenServer to TrueNAS-SCALE-21.08-BETA.1 , the iSCSI system can't connect.
Can anyone give me what is the correct multipath.conf configuration? or it's one problem of Truenas-SCALE?
Thanks in advance.
Seems to indicate that SCALE offers the same as CORE here.
However, you're dealing with BETA, so by all means, give feedback, but don't expect everything to work.
