TrueNAS Scale installation on partitioned drive
sinni97
i was messing around with TrueNAS Scale lately and i came across a guide on how to install TrueNAS on a partitioned drive by mirroring the initial installation onto the target drive with gpart. Unfortunately gpart isnt available in TrueNAS-SCALE-21.04-ALPHA.1 so far. The guide was this one.
For my specific setup it does make sense to split a 512GB SSD in half for Scale and for a regular Pool that will contain a bunch of docker images later instead of wasting the whole SSD for Scale.
Does someone found a solution to flash Scale on a small partition and use the remaining size for pools?
fdisk or gdisk?
If the content you want to store isn't incredibly important and won't change too often, maybe this would be a relatively simple option to use:
sinni97
fdisk or gdisk?
those ones are available but iam very unfamiliar with them. Do you have a guide for those utilities too?
I've looked through them but its and try the guides out, thanks.
sinni97
I did some testing and it worked well. So for everyone stumbling across this post i have noted down my steps to easily reproduce the setup.
sda -> small drive
sdb -> large drive
1: install TrueNAS Scale on smaller disk as usual
2: attach second drive and boot up
3: enable SSH in the UI and log into shell
4: backup partition tables from sda with gdisk
gdisk /dev/sda b (enter filename)
5: restore partition backup to sdb with gdisk
gdisk /dev/sdb r (recover and then l to load backup filename
6: Check the boot-pool status
It should display boot-pool and the largest partition of the sda drive like following
zpool status boot-pool pool: boot-pool state: ONLINE config: NAME STATE READ WRITE CKSUM boot-pool ONLINE 0 0 0 sda3 ONLINE 0 0 0 errors: No known data errors
7: Attach the sdb to the zpool
Keep in mind to use the largest partition which should be the same as on sda
zpool attach boot-pool sdb3
8: Copy the EFI Boot partition
dd if=/dev/sda2 of=/dev/sdb2
9: Copy the BIOS Boot partition (not sure if needed)
dd if=/dev/sda1 of=/dev/sdb1
10: Detach old disk (sda) from boot-pool
zpool offline boot-pool sda3 zpool detach boot-pool sda3
if it doesnt work boot from different disk and remove the other drive with
zpool detach boot-pool sdb3
Creating data pool
11: create additional partition starting from the end sector + 1 from the previously highest
gdisk /dev/sdb n (largest sector + 1 / BF01 type)
12: Get ID of new partition in expert menu (similiar 89530227-834A-4C91-8900-7B4210212E27)
I am not sure if it is really needed if you have a simple setup..
gdisk /dev/sdb x ( i to see GUID)
13: reboot and create pool from new partition
zpool create user-data /dev/sdb5 gptid/{ID}
alternatively without gptid but its harder to determine which drive it is on fault
14: Export the pool
zpool export user-data
15: Import pool in UI
imsocold
what if you only have a single drive?
Can you DD the drive to a file on another machine and then resize the partition?
