TrueNAS-SCALE-23.10.1.3 Shadow Copies not work on SMB shares
ADENNEDA
Hello!
Cant access any user to .zfs folder and Previous Version in Windows 10.
testparm -s
[pub]
ea support = No
guest ok = Yes
path = /mnt/ALLDISKS/public
posix locking = No
read only = No
smbd max xattr size = 2097152
vfs objects = zfs_fsrvp fruit streams_xattr shadow_copy_zfs ixnas recycle zfs_core io_uring
recycle:repository = .recycle/%D/%U
fruit:time machine = False
tn:vuid = 654f11c8-9c57-4c41-85fe-f878452e76ef
fruit:time machine max size = 0
fruit:resource = stream
fruit:metadata = stream
nfs4:chown = True
recycle:subdir_mode = 0700
recycle:directory_mode = 0777
recycle:touch = True
recycle:versions = True
recycle:keeptree = True
tn:home = False
tn:path_suffix =
tn:purpose = NO_PRESET
1. Didn't see any "shadow: snapdir" params...
2. Why "vsf objects" are "shadow_copy_zfs"? Samba docs says, what vfs objects need "shadow_copy2"...
zfs list -t snap
ALLDISKS/public@fss-2023-05-04_12-41 136K - 232K -
ALLDISKS/public@fss-2023-05-04_12-47 192K - 288K -
ALLDISKS/public@auto-2024-02-12_16-19 272K - 57.8G -
ALLDISKS/public@auto-2024-02-12_16-20 304K - 57.8G -
ALLDISKS/public@auto-2024-02-13_14-47 0B - 57.8G -
ALLDISKS/public@fss-2024-02-13_14-46 0B - 57.8G -
zfs get snapdir
ALLDISKS/public snapdir visible local
ALLDISKS/public@fss-2023-05-04_12-41 snapdir - -
ALLDISKS/public@fss-2023-05-04_12-47 snapdir - -
ALLDISKS/public@auto-2024-02-12_16-19 snapdir - -
ALLDISKS/public@auto-2024-02-12_16-20 snapdir - -
ALLDISKS/public@auto-2024-02-13_14-47 snapdir - -
ALLDISKS/public@fss-2024-02-13_14-46 snapdir - -
As you can see snapdir is visible. But in Windows and Linux client I can't open .zfs folder (also from root user) and Windows 10 "Previous version" list is empty.
Need help...
ADENNEDA
You have enabled fsrvp feature. This will only present snapshots created via FSRVP clients.
As you can see I have fss-* tag on snapshot - and windows didnt see it...
fsrvp was enables for test....
Other share without fsrvp...
testparm -s
[OTK]
access based share enum = Yes
ea support = No
guest ok = Yes
kernel oplocks = Yes
path = /mnt/ALLDISKS/OTK
read only = No
vfs objects = fruit streams_xattr shadow_copy_zfs ixnas recycle zfs_core io_uring
tn:purpose = MULTI_PROTOCOL_NFS
tn:vuid = 3b35b7fb-b5c8-4c35-a463-55b5d013d235
tn:path_suffix =
tn:home = False
nfs4:chown = True
Didn't work too...
zfs get snapdir
ALLDISKS/OTK snapdir visible local
ALLDISKS/OTK@auto-2024-02-15_14-28 snapdir - -
ALLDISKS/OTK@auto-2024-02-15_14-30 snapdir - -
Hello everyone
I have the same issue as Adenneda.
I created a dataset "bs2-poc" which is shared over smb. I set "Snapshot directory" to visible and I can see the .zfs directory in my smb share.
I can access the .zfs and .zfs\snapshot\ directories when connecting via ssh, but not via the smb share. I use the same account for both. For smb, I receive the error "the request is not supported". Also, there are no entries shown in the "previous versions" tab in the windows file explorer.
If I create a symlink to .\zfs\snapshot\manual-2024-02-19_12-18\ I can access the sub directory in the smb share.
Is this a permissions issue?
Any help is highly appreciated!
ADENNEDA
Hello everyone
I think what it's a permission issue, but I'll tryed to change permissions for .zfs folder to 0777 or 0755 - did't help.
Also I'll tryed to connect to SMB share by root user (or any @owner user) - anyway, I'll get same error as you.
I think what TrueNAS Scale does not allow windows to zfs folder, because user can't access to revert snapshot. But documentation says what windows user have readonly access to "Previous versions".
Bug? Or feature?
beagle
@anodos is the expert, but based on what I can understand from his previous post shadow copies and ZFS snapdir visible are incompatible if you use NFSv4 ACL:
In case of POSIX1E ACL code path samba synthesizes a generic NT security descriptor based POSIX mode. Similar logic isn't present in NFSv4 code, and so I'm adding for 22.02.2. I will also add logic to disable shadow copies automatically (and maybe generate alert) if ZFS snapdir is visible over SMB since the two options are somewhat incompatible.
ADENNEDA
WOW...
Man! Thank you!!!
Ok. What I have now:
1. I Set Dataset to POSIX
2. I Set Mask, Group to RWX
3. I Created SMB share to dataset
After this settings I can open .zfs folder and now I see "auto-2024-02-21_1200" folder can open it and can see any of snapshot files....
BUT... But I didn't see any snapshot in "Previous version" tab if I open "properties" of root share...
Anyway, it's 90% for resolving this problem...
