TrueNAS Replication Task Not Completing When Remote Destination Locked
swiney89
I have a TrueNAS CORE server (TrueNAS-12.0-U8) running a replication task to a TrueNAS SCALE server(TrueNAS-SCALE-22.02.2.1).
I have encryption turned on for the remote server and have input the passphrase for the remote server.
If I unlock the dataset on the destination manually, it will replicate just fine. However; if the remote dataset is locked at the time the replication runs, it will fail due to not having permissions.
I have verified that the passphrase in the replication task on the sending system is set properly.
Can anyone offer any insight into how to get this working in a way where I do not have to leave the remote dataset unlocked?
Attached is a photo of the error as well as the replication task configuration.
