TrueNAS pools and Hikvision IP cameras
K.J
I have the following question?
I installed a HDD that is only used as CCTV.
In it a pool containing three datasets, see pictures.
For each camera I created a dataset.
ipcam1 for ipcam1, ipcam2 for ipcam2 ipcam3 for ipcam3
In windows the three folders are visible and open.
Now when adding ipcam2 in hikvision I get the message that the folder is invalid.
Do I link the camera to the dataset of ipcam1 then it does work.
All setting, datasets, acl etc.... are exactly the same.
Would love your help. I am just a few days into treunas.
Greetings from the Netherlands.
Translated with www.DeepL.com/Translator (free version)
GBillR
Are you sharing as NFS or Samba? You did not post a picture of your share configuration.
Looks like your camera is expecting a NFS share, which you ordinarily would not be able to see in windows file explorer like your picture shows.
I recommend sharing as NFS and trying to connect again.
K.J
Hi @GBillR
Indeed i had not made nfs for ipcam2 and ipcam3
Now it does work.
Thanks for your help!
