Truenas loses network connectivity when fiddling with jails
clusty
I've been plagued by this issue for a while now and I might have gotten to bottom of it (still can't explain)
Randomly, my TrueNAS 12/13 installation is losing network connectivity (as well as the jails).
The "fix" seems to be changing router ports and rebooting the NAS.
The issues seem to be correlated with creating / starting / stopping jails or plugins.
The IPMI interface is very much alive alive throughout the whole process.
My ethernet card is Intel based.
Any idea what could be going on?
I could post more info if it would help getting to the bottom of the problem.
Patrick M. Hausen
Please post the complete output of ifconfig and the output of iocage get all <jailname> for one of your jails that triggers the problem. Both commands on the NAS host.
Kind regards,
Patrick
clusty
Kind regards,
Patrick
Thanks a lot for the reply:
Here are the info you requested (I masked some Mac addresses).
For some reason now it seems to be working...
Could my UniFi router be to blame for this instability ?
  • iocage.txt
  • ifconfig.txt
Patrick M. Hausen
This or a wrong bridge configuration, possibly. I'll look into it tomorrow if I have the time. Bedtime for now ...
Patrick M. Hausen
You have four virtual network interfaces, so probably four running jails - but only one is a member of the bridge0 interface. Did you configure all jails with VNET enabled?
What you should do in my opionion:
* boot the system with all jails "boot" option disabled - this effectively removes the bridge0 interface
* manually create an interface named bridge0, type BRIDGE, only member ix0
* test, save
* edit ix0: remove IP address, enter "up" in the options field, check "disable hardware offloading"
* edit bridge0: put IP address from previous step on this interface
* test, save
* reboot, check if everything apart from the jails is working
For each jail:
* change vnet_default_interface from "auto" to "none"
* ensure that interfaces is set to "vnet0:bridge0"
* re-enable "boot" option
Reboot the machine one last time and check if all jails are coming up OK.
clusty
* test, save
* test, save
For each jail:
Will try now :)
I did set all jails with vnet (default option). Do I need VNET ? :) All jails are set with DHCP rather than NAT since this simplifies the port forwarding (I suck at firewall rules and local host management is a bit easier)
clusty
* test, save
* test, save
For each jail:
I've done a simpler setup and things seem to "sorta work". I switched everything to static IPs and stuff comes up more reliably (not 100%).
A fix is to plug/unplug the ethernet on the NAS box.
Could the motherboard NIC be turning to shit ?
