TrueNAS Keeps Crashing
I just recently installed the new TrueNAS update and my server keeps crashing when loading the TrueNAS Software or after a minute of running. I also just recently removed and created a new pool. I also upgraded the ram from 8GB to 12GB. When I put the old ram setup back into the server I still receive the same problem. I was wondering if there was a way to reinstall my TrueNAS OS back onto my flash drive without losing the pools that I have already created.
diedrichg
A. Rollback to the previous version (System>Boot)
or
B. Backup your config, reinstall, and then upload config (unnecessarily time consuming, just do "A")
c77dk
If you've enabled new featureflags on the pool you can't revert, without nuking it all.
