Hello and Happy 2022,
I'm running iobroker in a Truenas jail (12.2 release p11). All updates done. Iobroker is basically running, except for the modbus adapter. Error messages are:
The .xx.50 IP is iobroker which want's to talk to the modbus instance with port 502 on IP 192.168.178.11 (small plc).
I have another instance of iobroker running under debian on another machine which is working perfectly fine with the modbus adapter.
With my limitted UNIX knowledge, this sounds like a rights/permissions/closed port/you name it problem.
Any thoughts??
regards Matthias
Quelle | Zeit | debug | Nachricht |
host.freenas-iobroker | 2022-01-02 16:36:49.223 | info | Restart adapter system.adapter.modbus.0 because enabled |
host.freenas-iobroker | 2022-01-02 16:36:49.223 | error | instance system.adapter.modbus.0 terminated with code 1 (JS_CONTROLLER_STOPPED) |
host.freenas-iobroker | 2022-01-02 16:36:49.223 | error | Caught by controller[0]: at processTicksAndRejections (node:internal/process/task_queues:84:21) |
host.freenas-iobroker | 2022-01-02 16:36:49.223 | error | Caught by controller[0]: at doListen (node:net:1505:7) |
host.freenas-iobroker | 2022-01-02 16:36:49.223 | error | Caught by controller[0]: at listenInCluster (node:net:1367:12) |
host.freenas-iobroker | 2022-01-02 16:36:49.223 | error | Caught by controller[0]: at Server.setupListenHandle [as _listen2] (node:net:1302:21) |
host.freenas-iobroker | 2022-01-02 16:36:49.222 | error | Caught by controller[0]: Error: listen EACCES: permission denied 192.168.178.50:502 |
![]() modbus.0 | 2022-01-02 16:36:49.199 | warn | Terminated (UNCAUGHT_EXCEPTION): Without reason |
![]() modbus.0 | 2022-01-02 16:36:49.198 | info | terminating |
![]() modbus.0 | 2022-01-02 16:36:49.184 | error | Exception-Code: EACCES: listen EACCES: permission denied 192.168.178.50:502 |
![]() modbus.0 | 2022-01-02 16:36:49.184 | error | Error: listen EACCES: permission denied 192.168.178.50:502 at Server.setupListenHandle [as _listen2] (node:net:1302:21) at listenInCluster (node:net:1367:12) at doListen (node:net:1505:7) at processTicksAndRejections (node:internal/process/task_queues:84:21) |
![]() modbus.0 | 2022-01-02 16:36:49.183 | error | uncaught exception: listen EACCES: permission denied 192.168.178.50:502 |
![]() modbus.0 | 2022-01-02 16:36:49.021 | info | State value to set for "modbus.0.info.connection" has to be type "string" but received type "number" |
Any thoughts??
regards Matthias
