TrueNAS Core USB Install - Reboot when Kernel Loads
beerat10
I'm using rufue to write UnRAID (TrueNAS-13.0-U5.iso and tried TrueNAS-13.1-MASTER-202401240815-159bf8b.iso) to a USB. When the kernel loads and gets up to
atkbd0: <AT Keyboard> irq 1 on atkbdc0 the system reboots.
I'm able to install Windows 11 & Unraid on the same box. I've spent hours playing around with the BIOS. It is up to date, but I can't apply the latest firmware. If I do the program says my BIOS isn't the latest version. I've logged a case with Asus on it.
Motherboard: Z10PE-D8 WS
Manual at: https://dlcdnets.asus.com/pub/ASUS/...8_WS/Manuals/E15493_Z10PE-D8_WS_UM_V7_WEB.pdf
Ai Overclock Tuner: Auto
Spread Spectrum: Auto
Xeon Turbo Charger: Auto
Trusted Computing: Disable (No TPM Chip)
Enable ACPI Auto Configuration: Enabled
CSM Support: Enabled
GateA230 Active: Upon Request
INT19 Trap Response: Postponed
Boot option filter: EUFI only
Network: EUFI
Storage: EUFI
Video: EUFI
Other PCI Device: EUFI
Hyper-Threading: Enabled
Check CPU BIST Result: Disabled
Monitor/Mwait: Enabled
Execute Disable Bit: Enabled
Enable Intel TXT Support: Disabled
VMX: Enabled
Lock Chipset: Enabled
Hardware Prefetcher: Enabled
Adjacent Cache Prefetch: Enabled
DCU Streamer Prefetcher: Enabled
DCU IP Prefetcher: Enabled
DCU Mode: 32KB 8Way without ECC
Direct Cache Access (DCA): Auto
DCA Prefetch Delay: 32
X2APIC: Disabled
AES-NI: Enabled
Down Stream PECI: Enabled
Please help so I don't move to Unraid.
Thanks
beerat10
I have installed TrueNAS SCALE. I was able to install it, however It still hangs while the kernel loads. I've tried booting into single user mode without success as well as blacklisting asus_wmi & eeepc_wmi which are ignored.
