Truenas core to scale upgrade error
nicosalto
i have been trying to update to TruneNas Scale from the web UI. I am currently on TrueNas Core 13.0 STABLE and i got this error while trying to install Scale AngelFish :
Error: [EFAULT] Command ['grub-mkconfig', '-o', '/boot/grub/grub.cfg'] failed with exit code 1: /usr/local/sbin/grub-probe: error: cannot find a device for / (is /dev mounted?).
Any idea why i get this error ?
Also would it be better to convert directly to Scale BlueFin instead ?
Thanks!
anodos
Sambassador
Thanks!
Angelfish is EOL. You should not be installing it on new deployment.
nicosalto
Thanks Anodos, would it be better if i convert to BlueFin instead?
