TRUENAS BIg BUG
bigfly
As long as the pool is damaged !
truenas cannot be accessed ,Can only force shutdown !!
I have a lot of hard drives, and forced shutdown will damage my hard drives!
what should I do ?????????
It's not necessarily the case, but some issues can occur with forced power cycles.
You have some pool recovery options available if a problem does happen, so you should do what's needed to have your server working.
anodos
Sambassador
You can switch to another virtual terminal while the keyboard + monitor are connected by hitting "control" + "alt" + <number>. That should bring you to a prompt for username / password.
