Hackslash
- Jun 2, 2021
Long time listener, first time caller. I've seen similar threads but I haven't found a good explanation for what causes this alert; what is the threshold or criteria. Nor have I found resolution for my situation.
I have a zpool with an array of 5 disks. Ever since I turned on email alerts I get around 4 alerts daily with the same message "Device is causing slow I/O on pool tank" citing various disks. Sometimes it's one disk. Sometimes it's all 5. The IDs are constantly changing between slow and cleared. Sometimes it happens 5 days in a row. Sometimes it goes 5 days with no alerts. I say "randomly" because I have yet to see the pattern. There may be some system task, or scheduled task that is causing it.
Questions:
Questions:
- What is the criteria that throws this alert?
- Is it configurable?
- This this a normal alert that happens when certain task run, or does it indicate a problem?
- Should I be trying to tune this alert out? Or should I be troubleshooting a hardware issue?
