TrueNAS 13.0-U1.1 Planned for July 25th
morganL
Captain Morgan
Administrator
Nordlicht-13
Hopefully it will be possible to install the NextCloud-Plugin again.
morganL
Captain Morgan
Administrator
I believe those issues are related to the Plugin... not the base TrueNAS 13.0-U1.
My understanding is this was related to some bugs in upstream FreeBSD 13.1 packages. These have been resolved.
@Nordlicht-13 can you test again... see if the issues persist on your end.
Samuel Tai
I believe those issues are related to the Plugin... not the base TrueNAS 13.0-U1. I'll try to find resolution and schedule.
@morganL, there a bunch of plugins unable to install because they refer to py38-* libraries instead of the equivalent py39-* libraries, and are failing the pkg install during plugin creation. This includes the official NextCloud plugin.
morganL
Captain Morgan
Administrator
TrueNAS 13.0-U1.1 is being pushed out now. Should be available Now.
jlpellet
Applied 13U1.1 & installed properly on 5 systems. However, since 13RC1, I have had an ongoing issue on an interaction between SMB & TN OS not properly managing the Windows archive bit, which I use with xcopy in a batch file to determinte which files have changed. Simple, the attrib command from Win7 shell is unable to reliably toggle the archive bit. As a result, 1 server remains on last 12. All of the SMB "fixes" in 13 have not successfully resolved this. I have replciated this bahavior on mult TN system with updates & fresh install. I have documented this in a private conversation with anados supplying documentation & debug. Any suggestions welcome.
anodos
Sambassador
This bugfix contained the issues that I was able to reproduce which were quite serious for affected users. I am still investigating the issue with archive bit, but since Windows 7 is EOL it took the back burner.
tineidae
i updated 13.0-U1.1 today, at first everything looked fine, but then Veeam start complaining that all of my nfs based repos are offline. I checked the repo configuration and veeam and it looked good. In Veeam i tried to edit the repo settings but it got stuck for a very long time and then prints "Failed to create file in the specified directory no write access to destination". I did a restart of TrueNAS and our Veeam Server but that didnt solve the issue. The solution that worked for me is to downgrade to 13.0-U1, immedately Veeam reconnected all NFS repos without issues.
Any changes in TrueNAS 13.0-U1.1 that breaks or changes nfs behaviour? the repos in Veeam are all configured as NFS 4.1.
Sven
anodos
Sambassador
Sven
There are no NFS-related changes in 13.0-U1 -> 13.0-U1.1.
tineidae
Thats strange, i gave 13.0-U1.1 another go and the issue immediately came back. For now i downgraded again and plan a bigger maintanance window to do some more investigation and try to get a network dump to see thats happen between Veeam and TrueNAS.
anodos
Sambassador
There are no changes in the OS repo (we use kernel NFS server). One unrelated change in middleware repo. And some samba changes mentioned above.
morganL
Captain Morgan
Administrator
If you can reproduce the issue, please report a bug. We'd like to resolve it even if we can't guess what the cause is.
