TrueCommand SWAG/LetsEncrypt Nginx reverseproxy config
MrBucket101
This took me quite a bit of time tweaking to get right. It turned out the websocket was what was causing me some headaches.
I wanted to share my config for others.
truecommand.subdomain.conf
# make sure that your dns has a cname set for truecommand and that your truecommand container is not using a base url
server {
    listen 443 ssl;
    listen [::]:443 ssl;
    server_name truecommand.*;
    include /config/nginx/ssl.conf;
    client_max_body_size 0;
    # enable for ldap auth, fill in ldap details in ldap.conf
    #include /config/nginx/ldap.conf;
    # enable for Authelia
    #include /config/nginx/authelia-server.conf;
    location / {
        # enable the next two lines for http auth
        #auth_basic "Restricted";
        #auth_basic_user_file /config/nginx/.htpasswd;
        # enable the next two lines for ldap auth
        #auth_request /auth;
        #error_page 401 =200 /ldaplogin;
        #include /config/nginx/authelia-location.conf;
        include /config/nginx/proxy.conf;
        resolver 127.0.0.11 valid=30s;
        set $upstream_app truecommand;
        set $upstream_port 443;
        set $upstream_proto https;
        proxy_pass $upstream_proto://$upstream_app:$upstream_port;
        #enable websockets
        proxy_set_header Upgrade $http_upgrade;
        proxy_set_header Connection "upgrade";
Spencer Skinner
Can this be done using subfolder as opposed to subdomain? I am just getting a blank page when I attempt with subfolder.
