Just updated TrueCommand to 2.3.3 and re-added my TrueNAS SCALE systems to TrueCommand.
As I had changed the SSL port number, when try to launch TrueNAS interface the URL it generate does not contain the port number that the browser needed to connect to the server.
i.e.
URL generated - https://IP/ui
URL needed to connect - https://IP:port/ui
I had the same configuration with the previous version of TrueCommand and it works.
Best Regards
i.e.
Best Regards
