True NAS Core 13 installation on IBM X3100M4
I have IBM X3100M4 Old Server with Xeon E3 Processor ( 4 Core ), 8GB RAM, 1 x 250GB, 1 x 1TB HDD ( for Testing Purpose Only ), I downloaded the latest True NAS Core 13 and start the installation but faced the below error and installation stopped.
"pcib3: acpi pci-pci bridge at device 28.0 on pci0"
"pcib3: failed to allocate initial prefetch windows: 0xc0000000-0xc0ffffff"
what could be the reason?
Seems to be saying there's an issue with some device on the PCI bus 3...
Can you remove your PCI cards (the ones not necessary for the install disks) and try it again?
No PCI / PCI-E card installed in the server.
tried below commands but did not succeed.
set hint.acpi.0.disabled=1
boot
set hw.pci.realloc_bars=1 and set hw.pci.realloc_bars=3
boot
Can you install plain FreeBSD 13 on it?
Seems your system is somehow not compatible with FreeBSD then... maybe you need to look at BIOS settings that may be preventing the install.
Alternatively, you may find more success with TrueNAS scale as it's booted via GRUB, which supports a wider range of hardware.
Not-very-passive-but-aggressive
Might want to start disabling PCI devices in the system firmware until the error goes away, to identify the culprit.
