Im attempting to perform a full backup before i migrate my nexenta san to freenas.
I added a LSI-SAS-9207-8e to a C6100 48G CPU, to access an external cage. Cage has 4 x WD Red - 4T in Raidz1
I started doing zfs sends to the new machine. i see that all of the data is sitting in ram and is very slowly getting written to disk.
The controller and drives think there operating at 6G
This is how the partitions are aligned. Not sure if this is wrong or right?
FreeNas Alert shows this:
I attempted to add a system update on a different test machine and the USB stick got corrupted.
Any Ideas?
[nexenta458@freenas4582] /root% sudo smartctl -i /dev/da3 Password: smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p25 amd64] (local build) Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Red (AF) Device Model: WDC WD40EFRX-68WT0N0 Serial Number: WD-WCC4E6JFCDFK LU WWN Device Id: 5 0014ee 2b73f1b35 Firmware Version: 82.00A82 User Capacity: 4,000,787,030,016 bytes [4.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 5400 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-2 (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Mon Dec 7 11:12:15 2015 PST SMART support is: Available - device has SMART capability. SMART support is: Enabled
[nexenta458@freenas4582] /root% gpart show da3 => 34 7814037101 da3 GPT (3.7T) 34 94 - free - (47k) 128 4194304 1 freebsd-swap (2.0G) 4194432 7809842696 2 freebsd-zfs (3.7T) 7814037128 7 - free - (3.5k)
WARNING: Firmware version 14 does not match driver version 20 for /dev/mps0 OK: There is a new update available! Apply it in System -> Update tab.
Any Ideas?
