I have freenas installed and was working fine. However, I've moved to a new data center and had to update the primary subnet on the server. The problem is, no matter what I follow on the bootup freenas menu (off usb stick), I am still unable to access the GUI.
I even modified the nginx.conf file manually too as even after following the freenas menu options to update default network, static network, etc. the old IPs were still shown in the conf file. I changed them, saved, rebooted. Same issue. Can't even ping.
Any ideas? Correctly routed on the switch too, double checked.
