Trouble update ports jail after 9.10 upgrade
fillg1
Hi folks
After the 9.10 upgrade from 9.3 I have some trouble updating an existings ports jail.
portsnap fetch update works fine, but portmaster -a gives the following error
➜ / portmaster -a
===>>> The value of DISTDIR cannot be empty
===>>> Aborting update
and portupgrade
/ portupgrade
"Mk/bsd.port.mk", line 1162: UNAME_r (10.3-RC3) and OSVERSION (902001) do not agree on major version number.
/usr/local/lib/ruby/site_ruby/2.1/pkgtools/portsdb.rb:237:in `join': no implicit conversion of nil into String (TypeError)
from /usr/local/lib/ruby/site_ruby/2.1/pkgtools/portsdb.rb:237:in `index_file'
from /usr/local/lib/ruby/site_ruby/2.1/pkgtools/portsdb.rb:247:in `db_dir='
from /usr/local/lib/ruby/site_ruby/2.1/pkgtools/portsdb.rb:167:in `setup'
from /usr/local/lib/ruby/site_ruby/2.1/pkgtools/pkgtools.rb:242:in `init_pkgtools_global'
from /usr/local/sbin/portupgrade:531:in `block in main'
from /usr/local/lib/ruby/2.1/optparse.rb:880:in `initialize'
from /usr/local/sbin/portupgrade:238:in `new'
from /usr/local/sbin/portupgrade:238:in `main'
from /usr/local/sbin/portupgrade:2380:in `<main>'
Any idea how to fix this?
D
dlavigne
Guest
Does rebuilding portmaster or portupgrade fix it? eg. cd /usr/ports/ports-mgmt portmaster && make reinstall
fillg1
No
portmaster make reinstall
"/usr/ports/Mk/bsd.port.mk", line 1162: UNAME_r (10.3-RC3) and OSVERSION (902001) do not agree on major version number.
fillg1
➜ pkg update
Updating FreeBSD repository catalogue...
pkg: Unable to upgrade "FreeBSD" repo schema version 2010 (target version 2012) -- change not found
pkg: need to re-create repo FreeBSD to upgrade schema version
[port] Fetching meta.txz: 100% 968 B 1.0kB/s 00:01
[port] Fetching packagesite.txz: 100% 5 MiB 2.8MB/s 00:02
Processing entries: 100%
FreeBSD repository update completed. 24751 packages processed.
But portmaster -a and pkg update throw the same errors as before
D
dlavigne
Guest
Bummer, sounds like updating existing jails is no longer an option. While you could delete and recreate your jails dataset in order to get the updated template (as mentioned in the Release Notes), that's a bit extreme if you already have working jails.
fillg1
Sorry to here that, but in my case this not so important, it was mainly hosting the plex server, so a reinstall should be easy.
SlyBlue
I am having the same issue, also when I tried creating a new jail in 9.10 I get a new error: "pkg: wrong architecture: freebsd:9:x86:64 instead of FreeBSD:10:amd64"
D
dlavigne
Guest
Please create a bug report about that error and post the issue number here.
gladandong
Hope the following procedure works for you too.
  1. edit /etc/login.conf, add the line in Bold
    default:\
    :setenv=UNAME_r=9.3-RELEASE:\
    :passwd_format=sha512:\
  2. run this command
    cap_mkdb /etc/login.conf
  3. quit, re-enter the jail and try again.
Frank
TerranPhil
Short of recreating my jails which I have yet to try nothing in this thread has worked for me.
root@rad:/ # cd /usr/ports/ports-mgmt/portupgrade/ && make install clean
"/usr/ports/Mk/bsd.port.mk", line 1166: UNAME_r (10.3-RELEASE) and OSVERSION (903000) do not agree on major version number.
sremick
I just got bit by this. I had been running 9.2, I "upgraded" to 9.10 by installing clean via ISO onto a new USB boot drive, then importing my config. Everything (including my jail) had been working since, including updating ports. But today I'm getting this error.
fillg1
The following seems to work for me
In the jail
setenv UNAME_r 9.3-Release
and then as recommended in #2
now portmaster -a is working :smile:
diskdiddler
According to those bug reports "Not To Be Fixed" Doesn't instill confidence in the 9.2 / 9.3 upgrade process to be honest.
sremick
In the jail
now portmaster -a is working :)
Thanks. That worked. Much easier than rebuilding the entire jail from scratch.
nello
I'm trying to update handbrake within a myth jail that I created on an older version of FreeNAS and I'm getting the same mismatch error:
root@mythtv:~ # cd /usr/ports/multimedia/handbrake/ && make install clean
"/usr/ports/Mk/bsd.port.mk", line 1148: UNAME_r (10.3-STABLE) and OSVERSION (903000) do not agree on major version number.
Unfortunately, I don't understand the solution recommended above.
Could someone please explain it a little more fully?
Thank you!
- nello
fillg1
I will try ;-)
#enter your jail as usual, replace the one with your jail name oder number
sudo jexec 1
# in the jail set the environment variable
# after that you can use the portage system as usual
portmaster -adw
nello
