Trim my config backups
ethereal
i have a script that copies my config file - once a day. i have hundreds can somebody help me with a way of automatically trimming them to say 50 ?
my script is :
cp /data/freenas-v1.db /mnt/Storage/Storage/ConfigBackups/`date +%Y%m%d`_`cut -d' ' -f1 /etc/version|cut -d'-' -f2`.db
my script runs from a cron job. which is the easiest way to trim using my unc path?
the location is \\FreeNAS\Storage\ConfigBackups
thank you
find /mnt/Storage/Storage/ConfigBackups/* -atime +31 -delete
This will keep a month's worth of backups. Suggest you take a copy of your backups and test this out first before putting it into production.
ethereal
thanks for your reply. where do i run the command
ethereal
i created a cron job with:
and it worked great
Here is an example script I run as a weekly cron, which replicates using the GUI with export secret seed option.
#!/bin/sh
FILENAME="`hostname -s`-`cut -d' ' -f1 /etc/version`-`date +%Y%m%d`.tar"
#echo $FILENAME
tar -cvlf /mnt/data/Software/truenas/$FILENAME --strip-components=2 /data/freenas-v1.db /data/pwenc_secret
echo "Backup $FILENAME created"
find /mnt/data/Software/truenas/NAS-?-TrueNAS-*.tar -mtime +365 -exec rm {} \;
Make sure it has execute permissions
chmod a+x {filename}
Add to cron tasks
/bin/sh /mnt/data/Software/truenas/backup.sh
