freshfeesh
- Oct 10, 2011
Still in the playing around stage with my new NAS box using old hardware. I had 3 drives installed, all formatted as UFS volumes. For testing purposes, I wanted to get rid of all the UFS volumes, then turn one of the drives into a ZFS volume. I'm at what I'd call a power user level of Windows ability, but all the unix nomenclature for things is Greek to me. The only thing I see that resembles deleting a volume (icon with a big red X on it) is called export, so I did that to all three volumes. I get appropriate warnings about loosing my data, so I think that they're getting wiped clean. I didn't check the box for "mark disk as new", because I thought the next step was going to overwrite everything anyway. Now, though, I can't create either a new UFS or ZFS volume. When I go into the create volume window, I see all the disks with open check boxes next to them. But when I try create a new volume from one of the disks, I get a message that flashes at the top of the GUI saying "Error: [MiddlewareError: Unable to GPT format the disk "ada3"]", and the console readout at the bottom says "[a bunch of stuff, then...] operation not permitted". This happens the same for trying to create UFS or ZFS partitions, and for all three disks. I wasn't able to make anything happen with either Import volume or Auto Import volume. What do I do now?
