sunshine931
- Jan 23, 2018
My setup - 11.2 U1, in an ESXi VM, with a Dell SAS 6gbps HBA in passthrough, and a NetApp DS4246 tray of disks via multipath SAS. All drives are 3TB HGST 512 byte, with 2gb for swap and the rest used as the vdev's you see below. I do have a full backup, but REALLY don't want to have to redo everything and restore..
My issue - Well, I think I really screwed up this evening. I wanted to compare performance with/ without an SSD log in my pool, and accidentally added them as a new mirrored vdev instead of adding them as a log device.
My pool before my screw-up:
Then, I did this:
You'll notice I forgot the "log" portion of that last command.. and now my pool looks like this (note the new "mirror-8"):
And finally, my questions for the experts -
1. Is there any way to remove "mirror-8" from my pool? I believe the answer is a resounding NO, but it can't hurt to ask.. maybe something has changed.
2. Those two disks in "mirror-8" are my power-loss-safe SSDs. I'd like to use them for their intended purpose. Can I replace them with two new HDDs? I imagine I'd go through a procedure similar to replacing a failed drive in a mirrored pair.
3. If I CAN replace da33p1 and da34p1 with new HDDs, can I also increase the size of the mirrored pair? The two da33p1 and da34p1 are just 16GB of SSD. I'd much rather have two 3TB drives in their place.
4. Pending the drive replacement, should I be concerned with referencing them by their gptid, rather than "da" names? There's a very good chance those da names will change, and I worry this could affect my pool.
I'd sure appreciate any tips/ walkthrough around how to go about replacing those two SSDs with two 3tb HDDs if anyone feels inclined to provide that level of detail.
Thanks!
root@omega[~]# zpool status nebula
pool: nebula
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
nebula ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
gptid/2fdc125f-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
gptid/30816c63-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
mirror-1 ONLINE 0 0 0
gptid/31403c46-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
gptid/31f1f182-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
mirror-2 ONLINE 0 0 0
gptid/32a4cfa3-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
gptid/3356fcab-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
mirror-3 ONLINE 0 0 0
gptid/341311e6-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
gptid/34c9952c-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
mirror-4 ONLINE 0 0 0
gptid/3580b3ad-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
gptid/364188ba-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
mirror-5 ONLINE 0 0 0
gptid/370908e5-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
gptid/37cf00a5-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
mirror-6 ONLINE 0 0 0
gptid/388e6fef-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
gptid/3945fee7-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
mirror-7 ONLINE 0 0 0
gptid/3a08fb45-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
gptid/3ad7a643-15f4-11e9-b1b0-000c29f308bf ONLINE 0 0 0
errors: No known data errors
root@omega[~]#Then, I did this:
root@omega[~]# gpart create -s gpt da33 da33 created root@omega[~]# gpart create -s gpt da34 da34 created root@omega[~]# gpart add -t freebsd-zfs -s 16G da33 da33p1 added root@omega[~]# gpart add -t freebsd-zfs -s 16G da34 da34p1 added root@omega[~]# zpool add nebula mirror da33p1 da34p1
pool: nebula
state: ONLINE
nebula ONLINE 0 0 0
mirror-8 ONLINE 0 0 0
da33p1 ONLINE 0 0 0
da34p1 ONLINE 0 0 0
root@omega[~]#
Thanks!
